60000Km's , and Plugs have black carbon Buildup???
Rep Power: 0 60000Km's , and Plugs have black carbon Buildup???
All of my friends who have 2001, 2002 civics all have that regular "tan red" wear on their plugs. My 1.7EL ( which is just a civic with a simple VTEC in it) has black carbon deposits on all 4 plugs. I always put "super" in it. But I do not think it would cause these deposits. I do all of the maintenance, I changed the air filter 3 times already, and I use amsoil synthetic 5w30 every 7500KM's. Does anyone know how I can make the plugs wear like they are supposed to? BTW, I just put in 4 NGK Iridiums, and BOY what a difference in fuel economy and idle!
Is there something wrong with my engine? Or is this normal?
Thanks
Thanks
Rep Power: 259 Do you baby your car? That's most likely it. You're better off driving it hard ocassionally, it builds up the heat required to blow buildup out. I know, I used to work next to a smog station, the things I've seen...
Rep Power: 430 I had the same problem, mine were covered in carbon build-up and looked like ****. Also changed mine to NGK iridiums. Havent tried it out yet though.
Rep Power: 279 Hondas are high-revving engines by design. If you baby it too much, you'll get black plugs. The car needs a good high-speed run now and again to keep the internals clean.
Case and point: My first Honda, a 77 Accord bought in NICE shape from an older couple some time ago. It ran "OK", but sluggish. Plugs were black. I just started driving it a bit harder every day. After a week or so it really started picking up in speed and power. Plugs were clean. So were the valves and pistons, I'd figure.
That car ran till 2002. When the engine finally blew the head without warning, I figured it was time to move on. So I drive my 02 civic pretty hard at least once a week. It runs flawlessly. So don't be afraid to run it out some.
Rep Power: 0 You guys are great! Thanks
Thanks. I will try that.
I am just a little worried about pushing the car too much. Acura changed the automatic tranny this past winter, and I am nervous about putting too much stress on the second one. ( They changed it under warranty ); I think I'm gonna put amsoil synthetic ATF when I change the fluid.
My engine is a little noisier than it was when new, do you guys think I have to adjust the valves already??
Thanks for everything!
The Evil Genius
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
Cyborg Ninja
06-30-2021 07:16 PM
thana
06-15-2020 07:05 PM
tock172
07-21-2015 06:25 PM
