changing oil
Old Jun 26, 2004
cloudyy's Avatar
cloudyy is an unknown quantity at this point
changing oil
hi i'm new here. i'm changing oil on my friends civic. i want to use mobil supersyn, but i don't see a 5w-20. does anyone have any suggestions. also will a filter from a 00 accord fit on the civic? thanks.
also is there a search button, i can't find it.
Old Jun 26, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
you can use 5w-30 also if they have it. i don't think the 00 accord filter is the same filter, you'll need to get a new one, they're only $5.
Old Jun 26, 2004
cloudyy's Avatar
thanks for the quick reply
Old Jun 26, 2004
jttegx's Avatar
OMNES AD UNUM
sorry for hi-jacking this thread but is 10w-30 oil ok for engine too?
i dunno how to real motor oil labels... help me out =|
THANKS
Old Jun 26, 2004
Jo_Boo's Avatar
Jo_Boo is an unknown quantity at this point
It is best to use Mobil 1 0W-20 if you cant get 5W-20. You can use 5W-30 but you should replace it as soon as possible.
Old Jun 26, 2004
Skunk2ner's Avatar
heres a quick lesson in the SAE classification system...
when you read the oil, it will have a rating on it, labeled like; SAE 5W-20 for example. the numbers refer to the oil's viscosity or how heavy it is.
the first number (5W in my example) refers to the weight of the oil at ambient air temperature on start up... the oil's thickness when it is just sitting at normal temperature before the engine is started.
the second number (20 in my example) refers to the oil's viscosity at normal operating temperature when the engine is warmed up.
the heavy weight oils, or high viscosity oils, are best for high temperature areas, or race applications. low viscosity is best for cold climates, snow, etc...
hope this helps.
Old Jun 26, 2004
CivicsRdBest's Avatar
The search button is to the left of the quick links.
Old Jun 26, 2004
Skunk2ner's Avatar
searching is very helpful, and also helps us having to repeating answers. but he's new, so lets give him a break.
Old Jun 26, 2004
jttegx's Avatar
OMNES AD UNUM
YES SIR
and thanks skunk2ner for the info
Old Jun 26, 2004
^^ I wasn't trying to be mean or anything but if you look no one replied to that part yet
Old Jun 26, 2004
Skunk2ner's Avatar
haha, oops. sorry. i guess i should read ALL of the post next time.
Old Jun 26, 2004
dnbguy86's Avatar
dnbguy86 is an unknown quantity at this point
hope this helps.
UH dude, just a lil FYI, heavy oil isnt good for performance!
Old Jun 26, 2004
zen_master's Avatar
indeed, heavy oil...................
they use heacy oil back in my country, Indonesia......a number like 20W50....they actually use it on a civic..
can you believe that? however, the ambient temperature in my country is always 85-95F..........
they do that in order to "eliminate" the noises from the engine..
my opinion: 0W20 M1 from wal-mart
actually, honda filter's good, right? $15 for 3..........hehe
Old Jun 26, 2004
Skunk2ner's Avatar
if your racing and your engine is at high temperature for elongated amounts of time, you don't want oil that is too thin to coat and protect your engine. but you are right, if you are doing normal daily driving, heavy oil isn't good, it doesn't flow through the engine well enough. but for racing applications, heavier oil than that you'd use for normal driving is better.
Old Jun 27, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
0w-20 would probably be better since thats what mobil1 suggests using as a 5w-20 substitute.
Old Jun 27, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
You only use heavy oil if you want to keep the metal from touching metal in your motor. I use 20w50 in my 10 and 12 sec cars.
Old Jun 27, 2004
Skunk2ner's Avatar
when all else fails, RTFM
honda manual says to use 5w-30 if you cannot find 5w-20.
Old Jun 27, 2004
ctx66's Avatar
im sure thats what honda says, and im just stating what mobil1 says
the whole point of motor oil in general is to prevent metal to metal contact..lower viscosities will do this too.
Old Jun 27, 2004
Skunk2ner's Avatar
exactly! using a lower viscosity will actually help in daily driving. if you don't drive long enough or hard enough to build up exsessive engine heat, you shouldn't use higher viscosity oils. infact, the oil will be too heavy and will not travel fast enough to safely distribute thoughout the engine. the engine simply will not create enough heat to make the high viscosity oil 'thin out' so to speak. when the engine heats up to operating temperature, it changes the flow ability of the oil, this being why the SAE created multiviscosity motor oils.
if you're heading out to the race track, you might want to bump up to a 30 weight or maybe even 40 weight, depending on the ambient temperature and how long you will be driving.
Old Jun 27, 2004
jttegx's Avatar
OMNES AD UNUM
any recommendations for a driver who just does regular driving but pushes the car hard at times? i would race arandom person couple times but not everyday. i live in cali and weather here is usually hot as of now. im expecting 80-93 degrees pretty soon for summertime.
i've been using 5w-30 mobil 1 and wanted to try something else. so any recommendations?
thanks.
Old Jun 27, 2004
Skunk2ner's Avatar
i'd go with probably just 5w-20, but if you can't find that then 5w-30.
RIPSAW
Nov 6, 2015 04:36 AM
MegaBassX
Jun 11, 2015 08:52 AM
BootyDo
May 7, 2015 04:46 PM
silverdevil
20
Jun 2, 2007 04:42 PM
Grey
16
Jan 27, 2002 11:34 PM
