More Torque means More Pull To The Right?!
Old Mar 6, 2004
kenji4861's Avatar
kenji4861 is an unknown quantity at this point
So I'm heading to lunch with my co-worker and my co-worker said his friend stated that having more torque means that you have more power, but you will also be pulled to the right more.
It sounded ridiculous, but is there any truth to this? I'm guessing this guy just screwed up his alignment while modding his car.
Old Mar 6, 2004
rscivic's Avatar
rscivic is an unknown quantity at this point
I have had a big increase in torque in my car since I first got it- not sure where it started stock but now it is 189 ft # and yeah it PULLS but to one side specifically I don't think so.
I have been in some muscle cars before though that have pulled like that...
Old Mar 6, 2004
cambo's Avatar
I wish I was asian
depends.
Cars without an LSD transfer most, if not all, the power to one wheel (unless its AWD, in which case...*** you). Ever see some older honda civics do burnouts, then later when the smoke clears you notice theres only 1 tire mark? sort of like that. All the power is being transfered to one wheel. Usually its the right wheel if your going forward and the left wheel if you're going in reverse.
Now onto the amount of pull you get in a direction...i can see that happening...i guess.
Old Mar 6, 2004
abmerop18's Avatar
Jam out with your clam out.
^ ya, wtf that happened to me once. i had a spare set of hubs and tires and was burning them like crazy and then i see a big pile of tire shredding only on the passenger side and a tiny scuff mark on the drivers side.
Old Mar 6, 2004
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Okay guys, it's called torque steer. Most FWD cars don't have enough power to suffer from it, but it can be alleviated as before mentioned with an LSD. The Spec V, SRT-4, MSP, Focus SVT all are notorious for torque steer due to the torquey 4 cylinder FWD setups. Main reason for it is that with an open differential setup, there is no even transfer of power from one wheel to the other. In other words, uneven road, drivetrain setup, and many other factors go into which wheel will get more power than the other. With an LSD, they are torque sensitive, and will discriminate power transfer from one wheel to the next continuously to keep traction, alleviate torque steer, and pull you out of the apex of a corner. Hope that helps.
So the answer is YES, You will experience torque steer with an increase in power. Invest in an LSD, but I don't believe they make an LSD to mate with a D17 Tranny setup. If you go the K20 route there is more than likely many available to you.
Tochigi Fuji Sangyo and Quaife are two big name brands for LSD's.
Old Mar 7, 2004
EuroSpec328is's Avatar
EuroSpec328is is an unknown quantity at this point
I have 212 lbs-ft torque on my car and when I launch, the back sways to the right a bit.
Old Mar 7, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Took the words right out of my mouth....
Old Mar 7, 2004
AdamYYZ's Avatar
AdamYYZ is an unknown quantity at this point
What was said above is probably the case. But could it maybe be even simpler than that? All roads where I am slope toward the curb for drainage. So basicly if there is any upset in the cars traction more often than not it would pull slightly to the right would it not? I mean, assuming your driving on the correct side of the road LOL
Old Mar 7, 2004
hoho's Avatar
hoho is an unknown quantity at this point
how much does lsd usually cost??
Old Mar 7, 2004
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
my M sways to the right every damn time i spin the tires.
Old Mar 7, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
around $1000 for the real thing.
Old Mar 7, 2004
blkdak99rt's Avatar
Riceburners Bitch
blkdak99rt is an unknown quantity at this point
yea and if your in a v-8 when you light up the tires with even a lsd like i have or my friends mustang you will dance to the right.... same thing if i power brake in my truck even though both are spining to intiate the limited slip you first have to have some friction on the right side tire first meaning that when you first jump on it, it will float to the right..... atleast this is what i have observed
Old Mar 9, 2004
jonnyg's Avatar
E36 M3 Driver.
where did u get that from? your car is only rated at 193hp.
Old Mar 9, 2004
naptowncivic's Avatar
naptowncivic is an unknown quantity at this point
Torque steer is a pain in my ***. Try 270lbs of torque. I need an lsd bad.
Old Mar 9, 2004
civic01vtec's Avatar
yeah, i think quaife is around 800......i will eventually be getting that
Old Mar 9, 2004
blkdak99rt's Avatar
Riceburners Bitch
im close to 400 lbs of torque however i do have a lsd
Old Mar 9, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
yeah i wish i had that problem
Old Apr 5, 2004
E36 328 was under rated from factory. It actually came with 200hp at the crank and 212 torque. BMW wanted the M3 to seem MUCH more powerful than the 328 so they listed the 328 at only 190hp which was incorrect. I've done extensive research on this. Even called BMW NA and they verified that it actually does have 200hp. I've raced one E36 M3 before and we stayed even in the rolls, but from a stand he got me by about 4 cars. God I wish I had an M like yours, man. PM me, I wanna ask you a few things about your car.
Old Apr 6, 2004
Titleist71's Avatar
I love TORQUE!
Old Apr 6, 2004
RiceBuRNeR's Avatar
Turbo Member
Man since I put the turbo on my car torque steers so bad. hopefuly my phantom grip will fix that problem.
Old Apr 6, 2004
blkdak99rt's Avatar
Riceburners Bitch
Originally posted by Titleist71
I love TORQUE!
get a turbo diesel then
thana
Jun 15, 2020 07:05 PM
jbradley4809
Apr 7, 2017 04:23 AM
Matteo
Oct 25, 2015 05:46 AM
Kyrian
Jun 26, 2015 11:48 AM
wholt0
Transmission
Jun 11, 2015 11:15 PM
