I called BS on a coworker and got owned
Old Feb 16, 2004
Kadenx's Avatar
ok...so this guy I work with drives a beatup 82 volvo that took some type of front end damage and is missing a grill. The headlights are like taped to the various front supports and the car is primer black. Somehow, we got on the subject of turbos and he said he had a "turbotronic" t5......not a clue what that is. He says that he is running about 23 psi on the stock block (i4) and that he puts down somewhere about 220-240ish to the wheels.....I was very quick to call bs cuz 23 psi seems a bit much for a return of 240 to the wheels. To make his case worse....we were messin around on highway 83 and I smoked him....couldnt even see him in the rearview and Im driving a solara 2.4. Well, I called BS and he told me to go and look at it. We went out and he popped his hood. The first thing I noticed was the intercooler right in front of the radiator. I found the turbo pretty quick mounted to the manifold on the passenger side of the block. It wasnt a very clean setup considering he had flex tube extending his intake to the front under the intercooler. I couldnt even see a wastegate..
Well, does anyone know about early volvo's? I still find it odd that he is running 23 psi (his boost guage has no numbers....only colors) and only able to produce 240whp. Am I the one on crack? We were playing around again after work today and he was eating me alive! Im confused and my ego is sore.....Someone help me out. I will take pictures of his setup tomorrow so I can post them.
Old Feb 16, 2004
kenji4861's Avatar
kenji4861 is an unknown quantity at this point
I don't know much on what you're talking about but my gf's dad told me his old 86 volvo wagon had a turbo and I floored it.. and it didn't really move.
Old Feb 16, 2004
Kadenx's Avatar
Well, he definitely kept up with my car in lower gears.....by no means is my solara a competant sports car but it should be quite a bit quicker than a car that weighs about 700 lbs more than mine
Old Feb 16, 2004
SS109's Avatar
This shirt is Dry Clean only, which means it's dirty. -Mitch Hedberg
SS109 will become famous soon enoughSS109 will become famous soon enough
hmmm... sounds weird. time to investigate.
Old Feb 16, 2004
Kadenx's Avatar
Ill bring in pictures tomorrow.....
Old Feb 16, 2004
phatcyclist's Avatar
phatcyclist is an unknown quantity at this point
volvo inline 4s are INSANE (the stock turbo ones), they hold so much boost, and they will run for a long *** time.
Old Feb 16, 2004
Kadenx's Avatar
k thanks
Old Feb 16, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Just because a car has a turbo doesnt mean its fast. It could have 30 HP before the turbo spools and at 10 psi that would only give it approx. 130 hp total. So at 20 PSI the same car would have around 260...this is NOT wheel HP. So its quite possible for him to be at 23 PSI and only have 240 HP. Not saying thats the case for this particular car, but it is possible.
Old Feb 16, 2004
tripledoublegs's Avatar
Euro-Spec
that's one pathetic engine.
Old Feb 17, 2004
xX03EXx's Avatar
Sweetest Dude on 7th Gen
i say the same thing to myself every day
Old Feb 17, 2004
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
He could have a vacuum leak in one of his lines, think he's running higher boost, and be losing it all...
Old Feb 17, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
As I recall from the olden days, Volvo is responsible for the current widespread use of intercoolers. Prior to that most folks just blew hot air into their intake.
Their motors back then were also seriously understressed and it doesn't surprise me that they could handle decent boost. I think it was in '83 or '84 that a intercooled Volvo wagon had a faster time than a stock corvette (I think that was from Motor Trend). That's not to say that those Volvo's are still fast 20 years and a few hundred thousand miles later.
Old Feb 17, 2004
gipperkid's Avatar
gipperkid is an unknown quantity at this point
yes is it a volvo 240? it has the inline 4 (B21FT engine) 2127cc 2.1L SOHC K-Jetronic fuel injection intercooled
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
