100 percent octane
Old Nov 27, 2003
ferio's Avatar
ferio is an unknown quantity at this point
100 percent octane
hi can someone explain to me what will happen if i put 100 octance in my car? i mean will it do anything performance wise? keep the engine cooler etc? or will i fVck up my engine? thanks!
Old Nov 27, 2003
Mr.Modify's Avatar
why would you want to do that ? i doubt it would do anything performance wise ( like give you 100 extra hp LOL) but if you have no reason to put it in then why would you? And if you do have a reason what do you have?
Edit: where would you get some thing like that? at a race track?
Old Nov 27, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
It'll probably make the car run worse. The compression isn't high enough to burn it. The higher the octane, the harder it is to get it to detonate, so the engine will just have to work harder to run. Just put 87 in it. Thats what the car is designed and tuned to run on... anything higher is just wasting money.
Old Nov 27, 2003
cryption's Avatar
2003 Nissan Frontier
^^^ well put boilermaker ....
Old Nov 27, 2003
KingTorq's Avatar
KingTorq is an unknown quantity at this point
incomplete burn (burns too slow for a vic), =loss of power. it would prolly kill your cat by dumping too much unburned fuel on it. If you milled your heads down to, say, 13:1, and figured how to bump your timing up, then your car would sing on 100 octane, but would ping on 91.
your car is basically tuned for 90 oct. it may pull some timing if the gas is lower grade, and may do full advance (which aint much) if you run 91/93, but you may hit full anv. with 89- that is kinda car to car diff, and station to station gas quality.
Old Nov 27, 2003
HustleLikeMOFO's Avatar
HustleLikeMOFO is an unknown quantity at this point
WRONG!
I say this over and over in the gas threads, Diesel is the best way to go. Even though our cars are not designed to handle diesel, it still wouldnt hurt putting some in. You will get more hp (15-20 gains), better gas milege and you tires and paint will last longer too.
Old Nov 27, 2003
ferio's Avatar
no dude.. i was arguing with a friend.. you can buy em in some gas stations in cali(so i've heared) for 5 bucks per gallon.. i wasnt tryin on doin it.. i just want info so i could make him shut up on his theory..ok? anyway happy thanks giving to all!!
Old Nov 27, 2003
civicr34's Avatar
civicr34 is an unknown quantity at this point
i put 87 in my civic and when i get to 80 mph it smells like something died in my engine and then i dipped my finger in the gas tank nozzle are and wiped some residue from the tank and it smelled like *** so i put 93 and everything is good again
Old Nov 27, 2003
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
Originally posted by HustleLikeMOFO
WRONG!
too funny. the paint will last longer!
Old Nov 27, 2003
cryption's Avatar
awesome! i'm gonna go put diesel in my car right now cuz i need gas .... brb guys
Old Nov 27, 2003
Dr5D's Avatar
I put 100 octane in my car once, and it happened to be the same day my brakes decided to go out... so I couldnet really tell a difference, except that I was broke from paying 3.99 per gallon
Old Nov 27, 2003
cvcpwr2k2's Avatar
cvcpwr2k2 is an unknown quantity at this point
man, someone is gonna misinterpret and f*ck up their ride
Old Nov 27, 2003
nynezilla's Avatar
nynezilla is an unknown quantity at this point
the 100 octane fuel doesn't f@#k up your ride. out here in cali it is labeled as racing fuel at the pump. it is $5.50 a gallon and it is pretty tight because you can feel the little extra power from it. i talked to the clerk and he told me it is actually good for your car every once in a while.the thing that sucks is that they put a lock on the pump after eight o' clock.
Old Nov 27, 2003
calypso's Avatar
calypso is an unknown quantity at this point
what gas station is the racing fuel at ? or where in l.a. ?
Old Nov 27, 2003
Yea, a gas station clerk is a good person to take car advice from. You might as well take my comment serious about putting diesel in ur Civ....
Old Nov 27, 2003
Dark_Pyro7's Avatar
Dark_Pyro7 is an unknown quantity at this point
Why put into a car that only requires regular.
Old Nov 28, 2003
cvcpwr2k2's Avatar
i was referring to diesel, not 100 octane. i use 91 all the time. you can feel a little more pep, plus its better for your car, less sediment settles in your gas tank
Old Nov 28, 2003
BausHaug's Avatar
I Am The Funky Monkey!!!
BausHaug is a jewel in the roughBausHaug is a jewel in the roughBausHaug is a jewel in the roughBausHaug is a jewel in the rough
The only time I use a higher octane is when I'm going on long distance drives. When I lived up in Seattle, I got around 40mpg on 93 octane. When I made the same trip on 87, I only got 36mpg. I could only imagine putting in 100....hmmm....
Old Nov 28, 2003
SeCosCiV's Avatar
Pimp Juice Distributor
From: Dallas, Tx but now Virginia Beach, VA 'cause of job...
SeCosCiV is an unknown quantity at this point
I use the highest at the pump whenever I get gas, not diesel though, is that ok?
Old Nov 28, 2003
Originally posted by Prod
WEEEEEEEEEEEEEEEEEEEEEEE
actually, I use ONLY shell gas. 87 octane, and always fill it full and run to almost E.
Shell gas? Don't tell me you fell for that commercial that ony "Shell" gas gets you better gas milege.
Old Nov 28, 2003
nuffsed's Avatar
I use 91 and it works out cheaper because i get more mileage, and my car runs smoother...
but 100 would be a complete waste of money in my eyes... the car only needs 87...
Old Nov 29, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
Here's a question...if it would really hurt, would they sell octane booster?
Old Nov 30, 2003
Blainestang's Avatar
Blainestang has a spectacular aura aboutBlainestang has a spectacular aura aboutBlainestang has a spectacular aura about
Octane Booster isn't really for factory cars. If you read the bottle, it says "UP TO 50hp INCREASE!!!!! fine print: because higher octane allows you to up the boost on your car."
Generally cars are built to run a certain fuel, and unless you change the timing or something, it will run best on that. Now, many computers will 'learn' to get used to premium if you use it, and will run crappy on regular if you switch back, but it should 'relearn' regular and run just fine.
Also, probably about 2 years ago, MT or C&D did a test with different octane gas and the Honda Accord, which was built to run 87, actually LOST 5 hp when switched to 93!!!! Is it possible that some of the 'gains' from running premium in cars built to run 87 or whatever is in your mind, since you assume it SHOULD because its more expensive or more octane or whatever? Food for thought.
Old Nov 30, 2003
INCivic's Avatar
INCivic is an unknown quantity at this point
why use anything more than what is suggested?
i hear all kinds of excuses, but no real proof
Old Nov 30, 2003
shmeb's Avatar
shmeb is an unknown quantity at this point
I use 93. I get better mileage with it than 87 or 89.
Old Nov 30, 2003
Boiler_Room's Avatar
Boiler_Room is on a distinguished road
Could not have said it better myself...
Old Nov 30, 2003
hoho's Avatar
hoho is an unknown quantity at this point
u better be getting GOOD *** mileage wit the 93 to make up for the extra money u spent on the expensive gas....i jus use regular.....
Old Dec 1, 2003
centurioncivic's Avatar
centurioncivic is an unknown quantity at this point
if you still have a cat and run race gas ur gonna have a cloggedass cat after you run it. but if you dont have a cat go for it, my friend drop .3 sec. in the quarter on race gas.
Old Dec 1, 2003
Dr5D's Avatar
I just always use 92/93 cotane (cant remember exactly) and I hate switchign to somethign else in an emergency... only had to do that once tho
Old Dec 1, 2003
barfly's Avatar
barfly is an unknown quantity at this point
If you are already using the proper octane fuel, you will not obtain more power from higher octane fuels. The engine will be already operating at optimum settings, and a higher octane should have no effect on the management system.
from octane FAQ
