rsx type r?
rsx type r?
i saw a rsx type r engine for sale. is there such a thing? he said it was 220hp, i know thats 20 more then the type s. if there is such a thing what gives it the extra hp?
Search and Learn
Type R DC5
Engine type K20A
Cylinders/valves Watercooled IL-4
Bore and Stroke (mm) 86.0 x 86.0
Piston displacement (cc) 1998
Compression ratio 11.5
Max power (NET) kW(PS)/rpm 162(220)/8000
Max torque (NET) N.m(kg.m)/rpm 206(21.0)/7000
Fuel system Honda PGM-F1
(Electronic Fuel Injection System)
Gear Ratio
1st Gear Ratio 3.266
2nd Gear Ratio 2.130
3rd Gear Ratio 1.517
4th Gear Ratio 1.212
5th Gear Ratio 0.972
6th Gear Ratio 0.780
Reverse Gear Ratio 3.583
Final gear ratio 4.764
Steering / Suspension / Braking System
Steering Rack & pinion
Suspension (F/R) McPherson / Double wishbone
Braking system (F/R) Oil pressure discs
Performance
0 - 100 km/h 6.0 secs (est)
Top Speed 145 mph (est)
Max mph 146
0 - 30mph 3,0
0 - 40mph 4,2
0 - 50mph 5,4
0 - 60mph 7,1
0 - 70mph 8,9
0 - 80mph 10,9
0 - 90mph 13,8
0 - 100mph 16,7
0 - 110mph 21,2
0 - 120mph 26,1
TED 4,8
1/4 Mile 15,4 sec / 96mph
Type S
2.0L DOHC 16-Valve Engine
i-VTEC (w/ VTC)
Alternator
12V, 95Amp
Aluminum Alloy L4
Bore & Stroke (mm)
86 X 86
Compression Ratio
11.0 : 1
Displacement (cc.)
1998
Emission System
Designed To Meet US EPA / Environment Canada Stringent 2004 Tier-2 Standards
Fuel System
Programmed Fuel Injection (PGM-FI)
Full Electronic Direct Ignition System
Horsepower @ rpm (SAE Net)
200 @ 7400
Redline
7900 rpm
Torque (lbs.-ft)
142 @ 6000
Valvetrain
4 Valves; Chain Driven
Final Drive Ratio MT
4.389
Engine type K20A
Gear Ratio
Performance
Max mph 146
0 - 30mph 3,0
0 - 40mph 4,2
0 - 50mph 5,4
0 - 60mph 7,1
0 - 70mph 8,9
0 - 80mph 10,9
0 - 90mph 13,8
0 - 100mph 16,7
0 - 110mph 21,2
0 - 120mph 26,1
TED 4,8
Type S
i-VTEC (w/ VTC)
Alternator
12V, 95Amp
Aluminum Alloy L4
Bore & Stroke (mm)
86 X 86
Compression Ratio
11.0 : 1
Displacement (cc.)
1998
Emission System
Fuel System
200 @ 7400
Redline
7900 rpm
Torque (lbs.-ft)
142 @ 6000
Valvetrain
4.389
PunX
Sep 23, 2015 10:45 PM
