cars should be rated by how they were suppsoed to be driven...
Prowlin' with a Purpose
seriously... i mean fuel economy at "optimal conditions"? WTF is that? i mean it should really be on daily driving... same thing goes with HP/Torque... most ppl probablly wont ever use all 240hp from the v6 accord..... so make it say 160 in normal driving... or something like that...
and im sick of ppl driving sports cars like grandmas... cars should be driven like they were designed to be driven...
Back From The Banned!
Hmm.... maybe, maybe not, but would you really want to your engine spinning at 5000+ RPM's in 1st and 2nd gear all the time while youre driving? Try cruising with those conditions
Re: cars should be rated by how they were suppsoed to be driven...
so what your saying is in your past two cars, while not exceeding the speed limit aka no faster thn 65 you never went above 2nd gear? kinda sounds stupid to me. (since you can hit 65 in 2nd gear the higher rpm over what it woul be in third gear [at least in a civic engine] would put out more power and perform better)
Okay I think we are reading the statement different. The way I interpret it was that in 1st and 2nd gear always go over 5,000 rpms not staying there all the time. So in 2nd once you gone over 5,000rpms shift to 3rd. That’s how I understand it.
Ive shifted and continue at high RPM's on all of my cars, and ive never really had a problem. Just normal everyday driving i usually dont shift till 4000 for some reason. Especially with our cars, they dont really make any sort of "power" till over 3000. I guess it comes down to throttle response for me, even if im wasting gas.
So if you always wanted the max power, you'd have to drive constantly at 6000..... meaning taking it up there and LEAVING it there.
At any given speed our cars have a certain amount of resistance. There's wind resistance, internal drivetrain resistance, and rolling resistance from the tires meeting the road. If your engine generates more force than the resistance, you will accelerate. If your engine puts out less force, you will decellerate. If you reach an equalibrium in force your cars speed will remain constant.
With that in mind, while cruising, use the highest possible gear. That will conserve gas and provide the least possible wear to the vehicle. When you want to accelerate feel free to downshift and step on the gas. Wind the engine out if you want. The engine and driveline in our cars can take it. The only reason why you would want to short shift your engine and slowly accelerate is to conserve gas and thereby increases MPG.
Hmm... perhaps I should have mentioned the engine is MAKING max power at that RPM. But it seems like your explanation is saying the engine is making 0 HP when it's not accelerating........
about people driving sports cars slow. I see alot of old people in corvettes that drive slow as hell and my mom has a 02' trans am ws6 and drives slow as hell, but with me or my dad in the drivers seat the car does what it is supposed to. So if you are going to drive slow all the time and stop to make every turn, stick to your buicks, cadillacs, and lincolns.
Anyone get the new import tuner? VTC in i-Vtec can change the cam timing plus 50 or minus 50 degrees depending on how you drive. They also told you that Toda makes the only cams legal in the SCCA and that companies like Mugen (explains why they are using the cams) are using it in their race cars. Some cools stuff. The Toda cams are for the Type-R but can be used on the K20A and gave the car 220 horses.
Sweetest Dude on 7th Gen
You can easily see that engine RPM is only part of the equation towards determining the output of your engine with a little theoretical experiment. Keep your speed constant while in a low gear and your RPM around 6 grand. Now if you notice your throttle position, you will see that your foot might be roughly half way down. Press the gas pedal all the way down and your car will surge forward. Lift your foot and the car will slow down. Pretty obvious stuff.
This shows you how your cars engine RPM is more of a potential of power. Now the throttle body and fuel injectors act on the engine giving the cylinders the needed gas and air to make those MAX HP numbers. A dyno graph that is trying to show max torque and HP is ALWAYS done under WOT conditions.
So there is a difference in what you and I are saying. You seem to be saying that anytime the engine is at "that" rpm it IS making max power. I am saying that at "that" RPM the engine CAN make max power. It depends on throttle position. You should now understand why this statement ------>
personally i think the fuel economy is the dealer's last ditch effort to hook someone in the deal... i think that they should change those "estimated" figures to actual real driving figures
I agree. I get on average about five MPG less than what the sticker promised me. But then again, I drive like an A-hole.
Of course on the other hand, if you drive these cars fairly nice, they will get the sticker amount. My dad drove my car to Tahoe(which is a mountainous city in Nor Cal) and he got 40mpg....so it can be done, even up in the mountains. You just gotta show alittle self control if you want to see those figures. Cause we all know it is fun to wait till that little red line to shift
On our trip to VA from IL, my dad did 80 the whole way at about 3-4k RPM in a 2002 EX auto, and he got about 40-42 MPG.
When I use the car on the other hand, I drive it like I stole it. On days where I drive a lot, I live in the land of stop signs, so I get far less. Like a half a tank n 3 days or somethin like that.
usajags84
15
Aug 19, 2015 03:12 AM
tylerginevan
Apr 27, 2015 12:29 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
