engine warming up ?
Old Jun 30, 2003
slamtank's Avatar
slamtank is an unknown quantity at this point
engine warming up ?
Most people would warm up their engines before going down the road by letting it sit idling. That's exactly what the manual says NOT to do. It's better to warm it up by driving it conservatively after the oil pressure builds up and the oil circulates. (About 30 seconds)
somebody said that..is that true?
letting it sit idling is not-to-do?
do i just wait for 30 sec after start and drive it gentlely?
Old Jun 30, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
i always waited a good min b4 i drove off, no matter what the weather was,
Old Jun 30, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
i alwayz wait 30secs b4 driving so that the oil can circulate throughout the whole engine n then i just drive off keeping under 3k rpm until warm
Old Jun 30, 2003
JLODVO's Avatar
JLODVO is an unknown quantity at this point
i always warm the car up before i start to drive its best to warm it up. i start the car and light a cig wen im finish with a stick the i drive. (kids dont do this)
Old Jun 30, 2003
slamtank's Avatar
"Huh_Oh Sh*t! -> i alwayz wait 30secs b4 driving so that the oil can circulate throughout the whole engine"
yeh so what im asking is if 30secs is obviously enough or not.
"JLODVO -> i always warm the car up before i start to drive its best to warm it up. i start the car and light a cig wen im finish with a stick the i drive."
i kno warming up is the best.
do u start engine and light a cig and drive when u burn it out?
isnt it too long time? just asking..think if u do its same as letting it sit idling which is the manual says not to do
Old Jun 30, 2003
MMILX's Avatar
MMILX is an unknown quantity at this point
I never let it warm up. I turn it on, let the idle stabilize, and begin driving slowly. Warming up your engine does nothing for warming up the driveline. Nothing like beating on your motor while the gearbox is still cold...
Old Jun 30, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
I only let mine warm up when its freezing *** cold outside. other than that i crank it and go, but it seems like i let it idle for maybe a minute or so while I fumble around to put a different cd in. Other than that i just go.
Old Jun 30, 2003
flotsamm's Avatar
I let my needle reach the top of the "C" then drive off slowly until it reaches normal temp. Something about going from cold to hot too quickly bothers me..
Old Jun 30, 2003
Mbow's Avatar
The goal is to get the engine up to temp as quickly as possible w/o beating on the engine. This is done by driving conservatively until it reaches normal temp.
Old Jun 30, 2003
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
Wow.. I turn it on and go, I pull it fast out of the driveway then onto the street slowly.. then go moderate levels for a few minutes...then go hard..
Old Jun 30, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
I always let my car idle for at least 30 secs (if it's already warm), or a minute or longer (if the engine is dead cold and hasn't been driven for about 10 hours or more). I just like to give the oil a chance to circulate throughout the engine block. My rule of thumb for dead-cold engines is to just wait until the idle rpm starts to go down a bit.
Old Jun 30, 2003
JayFReaZy's Avatar
I always use my auto-start while im getting ready, and let it run for like 5-7min idling. Is that bad? When I get in my car, its all ready "warmed up".
Old Jun 30, 2003
7thGenerasianCivic's Avatar
I don't get why the manual says it's bad to warm it up?
Old Jun 30, 2003
slamtank's Avatar
it doesnt say its bad to warm the engine up.
what it says is not to let it idle for long time, not sure how long is "long time"
Old Jun 30, 2003
It's bad to let the engine idle excessively, because there is no airflow into the radiator (besides the radiator fan), and you are letting the engine build up heat while the cooling system is working hard to cool the engine. Not to mention it wastes gas and pollutes the environment.
However, it is fine to let your car idle for a very short while to warm the engine up. There is a certain temperature range where the engine is at its peak in terms of combustion efficiency. The quicker you can get to that point and stay there, the better.
mikemc422
Aug 9, 2018 05:41 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
cruisers10
May 12, 2015 10:46 PM
TheZodiac
May 10, 2015 09:05 PM
Ninetyatecivic
May 9, 2015 07:48 PM
