98 EX coupe - Driver side latch/actuator
Re: 98 EX coupe - Driver side latch/actuator
What are you stuck on?
Remove door panel, disconnect the electrical connectors, pop off a couple of the rods, undo the three bolts holding the latch. The one rod going to the outside door handle is a bitch to pop off, it's threaded so I just unscrew it. Once everything is disconnected/removed pull out the latch and actuator and then remove the accuator from the latch, I think it's just a couple Phillips screws.
nixyfior
Sep 14, 2015 08:32 PM
streetglower
Interior DIY
48
Feb 15, 2012 10:06 AM
laack
Feb 8, 2010 04:22 PM
gearbox
7th Gen Do It Yourself Articles
May 2, 2008 12:34 AM
