General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
2012 Civic VIN?
Old Nov 14, 2018
NJC1684's Avatar
NJC1684 is an unknown quantity at this point
2012 Civic VIN?
Hello, could someone tell me what the 6th digit in the VIN indicates? Reason I ask is that I need to replace the engine and the local yard has a low mileage 2014 engine only available. I noticed while searching on eBay that the engines state 6th digit either a "2" or "3". Well my car is a 2 while the available motor is a 3 and I'd like to know the difference and what else may need to be changed if I in fact purchase said engine. I did look up the VIN and my car was ma ufactured in Indiana while the donor engine comes from Canada.
Old Nov 15, 2018
Re: 2012 Civic VIN?
Digits 4, 5, and 6 typically designate the chassis code for the car
For 9th gen civics, they are as follows:
Civic Sedan (non-Si): FB2
Civic Si Sedan: FB6
Civic Coupe (non-Si): FG3
Civic Si Coupe: FG4
Civic Hybrid: FB4
Civic Si's have the same engine (K24Z7, 2.4L DOHC iVTEC)
Non-Si trims all have the R18Z1 (1.8L SOHC iVTEC) engine.
Old Nov 15, 2018
Re: 2012 Civic VIN?
You probably only need the engine code. Maybe R18Z1 ? (I'm too lazy to go open the hood of my 12 and look LOL)
Find your engine code stamped in this area (pic below)
Old Jan 29, 2026
bmnot's Avatar
bmnot will become famous soon enough
Re: 2012 Civic VIN?
The 6th digit in the VIN usually doesn’t directly define the physical engine block or bellhousing pattern; it’s typically part of the manufacturer’s internal coding for body style, series, or configuration, while the 8th digit is more commonly the true engine identifier. A “2” vs “3” in the 6th position often reflects production differences (market, trim, or assembly plant like US vs Canada) rather than a different engine casting.
Mio
Nov 16, 2018 12:37 AM
willban1
Apr 25, 2016 06:28 PM
Taurousan
Engine Swaps
Dec 27, 2013 04:59 AM
skaraider
Jan 4, 2011 10:56 PM
twiztedD17A1
Apr 6, 2008 08:14 PM
