Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Bigger Front Brakes
Old Apr 27, 2020
2018 Sport's Avatar
2018 Sport is an unknown quantity at this point
Bigger Front Brakes
Hello everyone I am currently in the process of looking around to find a bigger front brake kit for my 2018 Hatchback sport. I was thinking of buying some used Type R brembos but im not sure if they would fit. Seems like all the kits are at least $1,000 + and I'm looking for a cheaper option. Anyone have any ideas or suggestions?? Thanks
Old Apr 27, 2020
Re: Bigger Front Brakes
Hyundai Genesis brembos and Nissan Rogue (with 3rd row seat) rotors. Bolts right up, but you'll need +30 offset, +35s with 5mm spacers, or OEM rims with at least 20mm spacers to clear.
Old Apr 28, 2020
2018 Sport's Avatar
Awesome thanks Ill be looking into getting one of these. Know have any websites that sell them cheap or can buy used ones?
Also what year for the Hyundai and Nissan ?
Old Apr 28, 2020
Let me collect more data about the swap, because apparently DC5R brembos and S2K rotors are a bolt on upgrade, too. I'll post up what I find
Old Apr 28, 2020
Genesis/Rogue combo:
  • Calipers: OEM Genesis Coupe brembo calipers, any year. Caliper mounting pattern is the same as the 10thgen
  • Rotors: Front rotors (320mm x 26mm) from a Nissan Rogue that is equipped with 3rd row seating. From my bit of google searching, MY 2017+ S and SV trims may be your best bet
  • Spacers or aftermarket wheels (18"+ recommended) required for fitment (list below includes popular offsets for wheel choices on the 10thgen). Keep in mind that the spacer thing is approximate. The goal here is to get at least 3.5mm clearance between the caliper and the spokes of the wheel. The 20mm and +35 with 5mm spacer options are the ones I've read about working, and all those push the wheel hub to about the position that a +30 would.
    • 20mm spacers for OEM wheels (assuming +50 offset for OEM)
    • +45 offset with 15mm spacers
    • +35 offset with 5mm spacers
    • +30 offset with no spacers
  • Brake dust shield trimming is required
  • Because my google-fu is strong, found a link you can buy it as a kit, so no guessing required.
  • On one person's BBK setup, they used StopTech Sport 309.10010 pads. That said, any of the vehicles on the fitment list below that were equipped with OEM brembo calipers should fit:
    • 2004 - 2008 Acura TL
    • 2012 - 2017 Buick Regal
    • 2018 - 2020 Buick Regal Sportback
    • 2013 - 2019 Cadillac ATS
    • 2016 - 2020 Cadillac CT6
    • 2004 - 2019 Cadillac CTS
    • 2006 - 2011 Cadillac STS
    • 2013 - 2019 Cadillac XTS
    • 2016 - 2020 Chevrolet Camaro
    • 2014 - 2019 Chevrolet Corvette
    • 2005 - 2006 Ford GT
    • 2007 - 2014 Ford Mustang
    • 2017 - 2019 Honda Civic
    • 2010 - 2014 Hyundai Genesis Coupe
    • 2003 - 2015 Mitsubishi Lancer
    • 2009 - 2009 Pontiac G8
    • 2011 - 2011 Saab 9-5
    • 2017 - 2018 Subaru BRZ
    • 2003 - 2014 Subaru Impreza
    • 2013 - 2017 Subaru WRX STI
    • 2019 - 2020 Toyota 86
    • 2004 - 2007 Volvo S60
    • 2004 - 2007 Volvo V70
DC5/S2K Combo:
Old Apr 29, 2020
2018 Sport's Avatar
Holy crap man! Thanks for all the info super helpful!
Old Apr 29, 2020
lol, that's why they randomly made me an Admin here. Legit logged in one day and saw "administrator" next to my username.
also, been looking at the swap, myself. All the DIY stuff I see if for the Si, but read threads of people doing it on other trims, as well. For me, I'm prolly gonna do the swap after I get rims.
Old May 3, 2020
2018 Sport's Avatar
Hey Riceboy do you know if the Hyundai genesis rear calipers fit as well???
Old May 3, 2020
The rears are a bit trickier because of the electronic e-brake. From what I've read, no. Most of your braking power comes from the fronts anyways, so I wouldn't bother. Get a good pad and rotor setup and you should be good
On my 2002, I did a rear disc swap, and really only changed the pads once over the course of the 13 years I had the swap.
Old May 4, 2020
2018 Sport's Avatar
Yeah that's what I figured but just wanted to double check just so it would look uniform between the front and rear. Thanks again man!
Old May 5, 2020
np. What I was planning on doing if/when I did the brake upgrade was just to grab some rear rotors/pads from r1concepts.com. I've read nothing but good things about them, plus really good pricing for performance stuff. $107 for their "geomet" drilled/slotted rotors, and $71 for their standard line. They frequently have 10-30% off coupon codes, too. Like right now, for the next hour and 50 minutes, 30% off with the code "Force"
My friend got a full 4-rotor (plain)/ceramic pad setup for her '16 sonata for like.. $150 shipped with a 20% off code a few months ago
Darth
Buy, Sell, & Trade - Archive
16
Mar 1, 2006 04:33 PM
streetglower
Jun 9, 2004 05:10 PM
MoneyBags
Apr 14, 2004 09:30 PM
mark@ssbc
May 1, 2003 07:50 AM
MyOtherRideIsBritney
Jan 2, 2003 01:18 AM
