10th Generation Civic 2016-2021 Discussion for the 2016 to 2021 Honda Civics.
Chassis codes: FC1, FC2, FC3, FC4, FK4, FK7, FK8
low on gas light
Old Feb 13, 2016
civic444's Avatar
civic444 is an unknown quantity at this point
low on gas light
On the 2016 honda civic sedan my low on gas light pops on when tank is near empty or still has some gas left in the tank. My question is , on the speedometer does it inform you how many exact miles you have left before the tank is empty?
Old Feb 13, 2016
CraigW's Avatar
Re: low on gas light
Check for a "range" in the display near MPG info.
It has about ~2 gal left...... but I would not run it a whole lot past the notification.
The 3 indicators on my 13 certainly make you aware, I put gas in it to get rid of them.
Old Feb 14, 2016
pnamajck's Avatar
pnamajck is an unknown quantity at this point
civic444 … s'not a good idea to 'hot-dog' the fuel-gauge. once the range descends to "0" … there still remains a reserve of 1+gal … however, as craigw suggested … that's playing with fire. would you really want to put your friend's safety in such dire predicament?
according to pg# 71 on the 2015-civic-sedan owner-manual (ATR0154DOM.pdf):
Low Fuel Indicator
  • Comes on when the fuel reserve is running low (approximately 1.9 U.S. gal./7.5 Liter left).
  • Blinks if there is a problem with the fuel gauge.
  • Comes on - Refuel your vehicle as soon as possible.
  • Blinks - Have your vehicle checked by a dealer.
Old Feb 14, 2016
What trim car do you have?
Have you pushed all the buttons that control the display to see what is available?
Have you looked in your owners manual?
Old Feb 15, 2016
civic444's Avatar
Nothing in the owners manual about low fuel indicator but the gas pump icon does appear and light up as yellow when gas is low. I have the base model LX sedan 2016 I will insert image of dashboard when i get a chance . Display buttons? Will check that out
Old Feb 15, 2016
civic444's Avatar
Was this what you meant ? I had 45 miles left When i got to 39 the yellow gas pump icon appeared
Old Feb 15, 2016
CraigW's Avatar
Yes, range (on current amount of fuel in tank)
I used to run my 2010 long after 0 segments were left....but stopped doing so.
Old Feb 15, 2016
Was this not enough?
You'll probably feel quite embarrassed when you are stranded in the middle of a road because you let your new car run out of gas.
Old Feb 15, 2016
civic444's Avatar
You mean to tell me after the range was 0 your car still had gas in the tank or still ran on the road without conking out ? Did the numeral fall into a negative category on the dashboard ?
Old Feb 15, 2016
civic444's Avatar
No i agree with you but at least i know where i stand as far as remaining gas mileage. My Honda 2003 EX 6cyl accord did not have this feature so when i was close to empty i was in fear of the unknown
Old Feb 15, 2016
CraigW's Avatar
The 2010 did not have the MPG info just fuel gauge, and the light also came on at 2 segments remaining.
But yes, as mentioned even if your range was reading 0 you would still have some fuel left.
Old Feb 15, 2016
just not a good idea, though, as time passes, some debris could be at the tank, and it could get sucked into the fuel system.
In Winter, I also keep it at least half tank - who knows when i will be stranded. if engine runs, better to have heating.
Old Feb 15, 2016
civic444's Avatar
That is a great feature to know how many miles i have left. According to the specs the tank takes 12 gallons to fill . Am i right on that? With gas around $1.50 it will only cost $18 to fill the tank . Accord cost close to $30 to fill up
Old Feb 15, 2016
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
In my 2012 civic lx the light comes on with 2 bars/dots on the fuel gauge. took around 11 gallons of gas at that point. owners manual says tank hold 13.2 gallons. i'll check next time i refuel to see what range is left then I can figure how much fuel is left in tank
Old Feb 15, 2016
Who is gonna be the first one to run their car completely out of gas just to find an answer to an unnecessary question?
Old Feb 17, 2016
mikey1's Avatar
why bother letting your gas get that low in the first place?
i rarely ever let mine go below half, 1/4 at the most
thatcham
Sep 30, 2015 08:28 AM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
tropicola
Sep 25, 2015 07:02 PM
Biggunschad
Sep 11, 2015 04:06 PM
