Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Quick easy hp for circle track build
Old Mar 4, 2018
Fatcatter01's Avatar
Fatcatter01 is an unknown quantity at this point
Hi I'm new here and am building a circle track car car is a 2000 civic d16y8 I'm wondering what some basic cheap mods for a little bit of a power increase car will be completely gutted except for the driver seat and a rollover bar and we have to go n/a thanks
Old Mar 4, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Quick easy hp for circle track build
loosen the distributor, twist it back and forth. one direction will make the idle increase, and in that direction you can wallow out the three adjustment holes to make it rotate even farther. use premium fuel after doing this. slice the top of the intake off and and hog it out. clean it properly and JB weld it back together. grind the JB flush and coat with vht wrinkle paint to hide it.
remove more metal!!! there's always more metal to remove! imagine me standing there holding an angle grinder and betting $500 that i can trim off 100lbs of metal
Old Mar 4, 2018
mac25's Avatar
Dr Krieger of Modification
-Port and polished head
-larger intake/header/exhaust
-ported throttle body
-aftermarket camshaft
-replace windows with plexy (if allowed)
FWDMiniStock
Feb 26, 2020 11:45 AM
circletrack
Aug 2, 2018 05:44 AM
droppedcivic303
Apr 9, 2015 10:41 PM
do_it_right
Apr 2, 2011 03:30 AM
Radeo
Sep 12, 2010 01:18 PM
