Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Any exhaust systems/headers worth a darn?
Old Dec 29, 2015
Hamilton's Avatar
Hamilton is an unknown quantity at this point
Hello everyone, I'm new to the forums, I picked up a 97 civic DX (hatch)..(sorry I don't know all the sub models and exactly what they all mean yet, i do know mine is the most bare bones sub model, lucky me) for the cool price of 800 bucks. minor front suspension problems. (upper ball joint, wheel bearing) also the cross member is completely rusted out on the passenger side which is what brings up my next question about the exhaust.
Skip to here if you don't want to read my sob story
The exhaust system under the car now sucks worse than the rusted cross member, and even though I got the car on the cheap i want to fix it right. Do you all have a personal recommendation on a full system that is affordable, or at least a header/manifold that is affordable.
I say affordable in the sense of... I paid 800 for this and it's going to be my daily driver. I don't want top of the line but i don't want ebay either.
Old Dec 30, 2015
Re: Any exhaust systems/headers worth a darn?
If the crossmember is already rotted out, you may not want to put money in it elsewhere until you get it structurally sound.
It can get quite embarrassing when all 4 wheels don't point in the same direction and you're in a ditch (or worse) because of it.
Old Dec 30, 2015
Hamilton's Avatar
I already have a new cross member and all the front end suspension components , the exhaust would be one of those, "While I'm down there" type of things.
Old Dec 30, 2015
Give us a price range for what you're willing to spend for each
Old Dec 31, 2015
be careful on cheap cat converters, most last much less than OE ones. If you get them, be prepared to spend for another much earlier.
Old Jan 1, 2016
mac25's Avatar
Dr Krieger of Modification
I got lucky with a used Megnaflow cat. back for $150,
a high flow cat. for $100, and instalation for $150.
Sounds great... for a civic =D.
Old Jan 1, 2016
Hamilton's Avatar
i'd say anything from 100-400
any brands to avoid? I didn't really intend on going cheap with it
anything that made you like the m(a?)gnaflow kit over oem? have you noticed any increase in performance/efficiency/or just a healthier sounding engine?
Old Jan 7, 2016
mac25's Avatar
Well my car is heavily modified.
You will feel a difference with I/HE and a stage 1 cam, that's for sure.
I don't remember much increase other than throttle response with just Intake and exhaust (but back then I had a stock cam.
then I dropped in the cam. and felt that quite a bit, but still only had intake and exhaust.
Then I finally bought a header, thinking it wouldn't make a difference. Boy was I wrong! My fuel mileage increased by 40% (possible 48%, it was almost double), and the power increased a bit to.
So I f you get a stage 1 cam. make sure you do full exhaust, intake and header.
(I'm also have no rear interior, or trunk liner and have a lighter front end and fiberglass hood, so obviously the gains will reflect greater in my case).
nonickerson
Dec 27, 2015 10:29 AM
CurryBomb
Dec 19, 2015 10:30 PM
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
MamaBear2015
Dec 5, 2015 04:03 PM
Jonofish
Dec 1, 2015 02:15 PM
