Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
96 Dx mini me swap questions
Old Feb 18, 2013
96dx's Avatar
96dx is an unknown quantity at this point
Hey guys im new to this forum and was wondering if i could get some advice for my swap. Currently have a stock d16y7 and was looking for an ex to pull the y8 from. Also thinking of pulling the ex tranny and swapping that aswell. Any advice would help thanks.
Old Feb 25, 2013
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
Re: 96 Dx mini me swap questions
you will need a y8 cylinder head that is complete with intake manifold and throttle body if you can get it.
a knock sensor (get one for a 96 civic ex at the parts store) ~$120
a p2p vtec ecu from an ex. manual if your car is a manual. auto if it is auto.
about 4 ecu pins (from a yard where you get the ecu from or sometimes they pop up on ebay)
3 2 wire honda harness pigtails (for vtec pressure switch, iacv, and knock sensor)
timing belt and tensioner (waterpump if you want to do preventative maintanence)
odds and ends like wire to wire up your vtec solenoid and knock sensor 12-14g is fine.
vacuum line
also make sure since your car is obd2a that you get parts from a 96-98 ex not 99-00. they will work if you cant find obd2a but its just simpler to install.
as far as the transmission make sure you get a new clutch and flywheel or resurface the old flywheel at a machine shop.
a chiltons or helms manual should be your best friend if your not entirely sure how to do all the work.
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
ClutchMasterOG
May 31, 2015 03:25 AM
trellex
May 24, 2015 04:39 PM
viper775
Dec 9, 2001 10:52 PM
