Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
best fuel filter for D16Y7 1998 civic DX
Old Oct 28, 2012
WaryDriver's Avatar
WaryDriver is an unknown quantity at this point
First, what is the difference between 16010-S01-A32 and
16010-ST5-E02 honda fuel filters? Some sites say one is for my D16Y7 engine and others say the other part number is. Which one came with my car from the factory in 1998?
If I wanted, I could go locally and buy a Fram filter for a little cheaper. Which is better quality, OEM or Fram filter? What company makes the OEM filter...Filtech?
P.S. My engine has been taking multiple keyturns to start. Havent changed the fuel filter in over 20k miles. What else could be the culprit and should I examine?
Last edited by WaryDriver; Oct 28, 2012 at 12:40 PM. Reason: added hyperlinks to parts
Old Oct 28, 2012
GolNat's Avatar
Prelude Owner
Re: best fuel filter for D16Y7 1998 civic DX
Multiple key turns could be a lazy fuel pump. 20k miles isn't a lot for a fuel filter.
Old Oct 28, 2012
16010-S01-A32
Filtech, 2, 3, 4 door cars, comes with seals.
2 and 3 door app says ALL,
4 door app says US and CAN
(About $2 cheaper than the other filter according to my catalog.)
16010-ST5-933
Toyo Roki,
listed only under 4 door car, says ALL,
same as above, mix and sell identical parts.
Supercedes to 16010-ST5-E02
Probably all exactly the same, just different manufacturers.
Your starting complaint should have nothing to do with your fuel filter.
Pressure and volume testing would prove or disprove this.
HTH
Old Oct 28, 2012
WaryDriver's Avatar
Thanks GolNat.
Thanks ezone, as many times before, your reply was what I was wanting to know.
Can I just replace the filter element instead of the entire canister?
Old Oct 28, 2012
Sure. Get your can opener or tubing cutter to open it, and a welder to seal it back up again..... And search the net for a company that will sell just the element to you.
Tell me you ain't serious...
Old Oct 28, 2012
WaryDriver's Avatar
Serious about what? Didn't know how they're manufactured.
Probably going with 16010-S01-A32 (Filtech) since I don't want to deal with unmaking and remaking the canister. Its on ebay for $26. is that the cheapest place to buy them?
Old Oct 28, 2012
Look at it. You can't open it. You can only replace it.
$26.88 is MSRP.
You can get it cheaper, but is it worth it?
(I usually consider what time is worth too.)
http://www.hondaautomotiveparts.com/...L+PIPE+%281%29
Part #1, $19 plus shipping. Shipping charges may kill any savings though.
Someone posted this one the other day too, this is about 2 hours away from me. http://www.bkhondaparts.com/
HTH
mistermenphis22
Apr 3, 2016 08:06 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
dooner24
Apr 14, 2015 07:51 PM
Hrddrvs
Apr 11, 2015 11:22 PM
