Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Idle problem, Air control valve help.
Old Sep 15, 2012
Bishop1310's Avatar
Bishop1310 is an unknown quantity at this point
hey guys.
Im having some idling problems with my 2000 civic DX. The car is all stock. I want to clean out the idle air control valve. From what I've read online all my symptoms are indicating that I should clean it out. I'm having some weird fluctuations in my RPM's when sitting at a light, and sometimes the RPM's get really low, and I get a rough idle.
does anyone have any kind of diagram on how to remove the entire air filter assembly, and air control valve? I'm having a problem getting the air filter element off.
Thanks
Old Jan 21, 2013
98Honda4banger's Avatar
98Honda4banger is an unknown quantity at this point
Re: Idle problem, Air control valve help.
does the idle erratically fluctuate? or does it just idle too low. i had an erratic idle but that was after an engine swap and i didn't ground the wire from the iacv properly. Had me stumped for a couple of weeks and then i decided to completely rewire and realized my little mistake.
Old May 1, 2013
Hayden_Fourroux's Avatar
Hayden_Fourroux is an unknown quantity at this point
I had the same problem in my 97. Took apart everything cleaned it all. It didnt help at all. still idled at about 200 RPM. I just changed the alternator and it got rid of the problem.
Old May 1, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
^ post is 3 months old, but thanks for the insight. Might help someone anyway.
mikemc422
Aug 9, 2018 05:41 PM
crowtoo
May 11, 2015 06:50 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
mievil
Apr 28, 2015 11:02 PM
cooldan1
Apr 23, 2015 10:49 AM
