Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
engine fan problem??
Old Jun 1, 2012
jkidd209's Avatar
jkidd209 is an unknown quantity at this point
i have a D16Y7 and my fan wont kick on?? i hooked a wire to it and battery and it came on so i ended up wireing it to a toggle switch in my car as a temp fix so i can just turn it on manually. What could it be??
Old Jun 1, 2012
Re: engine fan problem??
Originally Posted by jkidd209
What could it be??
Broken. Duh.....
You should have the fan itself, a condensor fan if it has AC, a few fuses, a couple of relays, the PCM, a temperature sensor, and a pile of wire...
You need a wiring diagram and a plan.
You might be jumping the gun, too.
What makes you think it doesn't run?
What evidence do you have?
See the 2 wire sensor on the thermostat housing? Unplug it and jumper the 2 wires. Turn the key on. See if the fan runs.
Old Jun 1, 2012
jkidd209's Avatar
my evidence is when at idle no fan comes on ha and where can i find a wiring diagram?
Old Jun 1, 2012
Ha? What?
Idle means nothing.
The fan shouldn't come on until the coolant temp at the thermostat housing is 212*F. It can take a LOOONG time to get that warm, and if there is a cold breeze it may never need to run the fan.
Got AC? At least one fan should run when the AC runs.
blazebrown
18
Jun 2, 2019 12:31 PM
amrhamed
Aug 31, 2015 07:47 PM
crowtoo
May 11, 2015 06:50 PM
hokiedad4
May 3, 2015 10:06 PM
supercivic01
South
Nov 30, 2001 11:27 AM
