Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
tune up/basic performance questions
Old Mar 13, 2012
dkdontforget's Avatar
dkdontforget is an unknown quantity at this point
Hey everyone! I'm new here (haven't yet been able to update my profile cus I'm on my phone)
But, my mom is going to be handing me down her 2000 civic dx it have 175k miles on it, and nothing has been done to it besides a few basic tune ups and oil changes every three months
I'm just starting to get into cars and I want to know what things can I do to return some lost power (with the few things she's done there has to be things that need cleaned or replaced) and just make it run a little better
Also every so often when the car starts it idles pretty high around 1500 rpms, and its not just heating up it will stay like the for like 10 min even after driving. Then it will return to normal. Other times its just normal it only does it every so often
Old May 4, 2012
chris00SI's Avatar
chris00SI is an unknown quantity at this point
Re: tune up/basic performance questions
The idle air control module could be going out.
Old May 4, 2012
GolNat's Avatar
Prelude Owner
Clean the IAC valve and throttle body, that will help it idle and bring back lost power. Also check the plugs. If they are not NGK or Denzo then throw them out and get NGK or Denzo.
Old Jun 6, 2012
thanks, will do. i will also be going to stinson beach within the next few weeks (steep, hairpin turny moutain roads) and i was wondering what i should check because i dont want to get stranded. just got an oil change a few weeks ago and coolant level is good. the car has 180k mi on it if i didnt mention
2000 civic DX all stock
Old Jun 6, 2012
GolNat's Avatar
Prelude Owner
Sounds like a fun trip!! Check your spark plugs, air filter, all your belts, and tire pressures. If you want to make the mountain roads more fun and safe, replacing some worn suspension parts will help (ball joints, end links, control arm bushings, tie rod ends). It's up to you and how much you want to spend. If any of those things have never been replaced then they are definitely bad. Some of those suspension parts can be bad if they break (you will be stranded) but you will generally hear them clunking or knocking a long time before they give out.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Misfit2613
Jul 30, 2015 09:49 AM
krazykoncepts
Jul 14, 2015 01:55 PM
NoobyKid
Jul 13, 2015 07:53 AM
silentz
Jul 9, 2015 08:16 PM
