Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
The dreaded D16Y7 exhaust crack -___-
Old Oct 28, 2011
kyle_l88's Avatar
kyle_l88 will become famous soon enoughkyle_l88 will become famous soon enough
Hey guys, so basically, like a lot of other people on this forum, I have a HUGE crack along the center of the manifold where the four pipes meet. Rather than grab a nice new OEM one from honda I was thinking about going the other route and getting 4-2-1 headers. Thing is I still have the stock muffler system. I also need a catalytic converter somewhere in there because I have to pass emissions (even if its a shitty pass, i dont care as long as it passes every 2 years haha). Has anyone done the swap from stock to aftermarket while keeping the stock exhaust system? Help or a diagram/parts list would be awesome. Thanks.
Old Oct 28, 2011
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Re: The dreaded D16Y7 exhaust crack -___-
When mine cracked I used an aftermarket one, still keeping the stock exhaust system. Paid like $110 vs $300-$400 from the stealership. Mine's a D16Y8 AT.
Old Oct 29, 2011
kyle_l88's Avatar
Cool but did you end up getting rid of catalytic converter altogether? Cuz I need it for emissions so where in that set does it go? I know most of them have the 4-2-1 header system and it just bolts right up. Problem is i will never pass the emissions test.
Old Oct 29, 2011
lazlong's Avatar
Aftermarket cats suck. They have very little material in them, hence the cheap price. You might be able to pass emissions once.
See if you can find someone to weld the crack or go 4-2-1 and use the bypass trick: https://www.civicforums.com/forums/2...on-w-pics.html
Wolfcamp
Aug 14, 2015 08:52 PM
Chatito
Aug 14, 2015 02:04 PM
bhollie
Aug 12, 2015 09:58 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
hayden55
Jul 8, 2015 11:38 PM
