does anyone know of any motor mounts
Originally Posted by Shlomo
so these motor mounts reduce engine vibration (engine movement) but increase the vibration of the car itself, right?
Once you go Black on Black, You Never Go Back.
dude what was the part number to your mounts you got from summit, i called them today then checked my order online and they are sending me ones from the 6th gen - i was like what the fu*k
ok so i just called back and complained to the guy that i was sent the wrong inserts, the part number ENS-16-111R is the inserts for the 01-03 civic RIGHT?????
I just ordered a set from Options Auto, They had them in stock and they shipped the same day. They should be here next Thursday. Here is the link, it came to like $30 shipped, hopefully these will help things like some of had said it helped eliminate wheel hop...
http://www.optauto.com/index.htm?sto...=ES16-1111%20G
I'll post again when I have them installed....
Hey I was gunna put my inserts in last weekend, and when I decided to do it i got conufsed. Do you have to take the bolt out? Some of you mentioned it only took 5 minutes for the front, if that bolt comes out how do you get the insert in and how to hold up the engine???
slight improvement in my 60 ft. Having the ability to launch at a higher rpm with less hop helps alot. I am still learning tho.
Hey - what's the scoop on these? do they fit into the stock motor mount? Or do they press into it? I tore mine, and need replacements - do I need a new stock one before installing these or what?
If you tore your stock mount you will have to get a replacement, then install the inserts. IMO these would be a must for boosted cars. The front mount is so wimpy stock. These just slide in on either side of your stock mounts taking up the gaps, making them almost like solid mounts.
Thanks for the info...
AKA Mr. 60ft. Not to be confused with Civic_Redline
well mine never came today!!!!
may have to postpone trip to the track till next weekend, which sucks because i was gonna run a couple guys from work. 04 RalliArt Lancer and a 90 RX7 gtu. Now I'm gonna look like a chump backing out.
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
