Where to get clutch?
Old Apr 23, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
I dont know if this is a repost, but I need a new clutch. Anyone know were to get an act or centerforce for cheap?
Old Apr 23, 2003
cdmx's Avatar
i can tell you where to get an exedy sport clutch (same as factory, but sport)
for around 250-275
Old Apr 23, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
well the common answer is going to be ebay. i would say there or autodynamic.com
Injen
Old Apr 23, 2003
cdmx's Avatar
Organic disc facing - 235.68
ceramic-metallic disk facing 3-Puck Clutch Disc - 312.89
Old Apr 23, 2003
cdmx's Avatar
hey someone tell me why a sport clutch comes in a "multiple puck" design....How is this better? or does it just have better clamping power
Old Apr 23, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
I got the cm clutch and fidanza flywheel off a group buy for cheap. they say cm is better than act because...
"Just to let you know Clutchmasters makes a better clutch one that is has less pressure to your foot (Called pedal pressure) ACT is know for having high pressure and make you feel like you are doing foot exercises. We also sell ACT and can try to match his prices. Please email us the part numbers"
go here: http://www.groupbuycenter.com/buy.aspx?id=9772
you'll want to order these part numbers if you want a stage 2:
Fidanza Flywheel # 191161 & 08-022-HDKV
Old Apr 23, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
sounds like a good setup to me. I just got my ACT HDSS clutch today and should have their streetlite flywheel by friday, install will be in two weeks. I have heard great things about fidanza flywheels, and as for the clutch it was a tossup for me bw CM, ACT, and CenterForce and it eventually landed on ACT (it is just their heavy duty pressure plate, so pedal effort should not be toooo horrid ) I ordered my ACT stuff from www.lakeeffectperformance.com and www.optauto.com for anyone else wondering....
Old Apr 23, 2003
bublik's Avatar
Truehonda.com
Well, I need something that holds nitrous. Tell me were to get.
Eddie
Old Apr 23, 2003
bublik's Avatar
Truehonda.com
Old Apr 23, 2003
Intruder's Avatar
Just about any aftermarket performance clutch will hold nitrous well. I have heard from si and integra guys that exedy's (one of their sport/upgraded clutches) are a little bit on the weak side if you are spraying alot or often or running higher horsepower via all motor or FI, but they also have a nearly stock pedal feel. Its pretty much a preference thing between Clutchmasters, ACT, and Centerforce (all of which are reasonably priced)....
Old Apr 23, 2003
cdmx's Avatar
what about that 3 puck im guessing "stage 2" exedy sport clutch
Old Apr 23, 2003
bublik's Avatar
Truehonda.com
price and were to buy?
Old Apr 23, 2003
RoBBUsaF's Avatar
www.groupbuycenter.com or do a search.
Old Apr 23, 2003
bublik's Avatar
Truehonda.com
What do you guys think of exedy racing clutch or the sport? I know exedy makes the stock clutch so...wad ya think? Anyways, thanx for all the help. I am guessing I am going to need it with the N20. Hey, can I blow the gears, or are they fine?
Old Apr 24, 2003
cdmx's Avatar
yes anyone know anyone who tried the Exedy (Daiken) "racing" 3 puck ceramic disc facing clutch....OR the exedy sport clutch??
Old Apr 24, 2003
old beater's Avatar
old beater is an unknown quantity at this point
i have the exedy racing clutch. got it from coximport.com for like 250 or somewhere around there. its got a bit of a heavy pedal feel but not too bad. holding power is good when its broken in correctly. i got the kit whitch came with throw-out bearing, pressure plate, and clutch. i like mine its a nice clutch, but if you are spraying or going to be i dont know if i would reccomend it.
Old Apr 24, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Why would you not recommend it? Its made to handle the horsepower. Ever driven a stock WRX? The pedal is heavy and is hard to smoothly leave the line.
Old Apr 24, 2003
bublik's Avatar
Truehonda.com
I found an ebay store that does 250 shipped for Exedy Sport/Racing! Holds 70% over stock!!! If anyone needs, maybe a groupbuy can result in like 200 shipped!
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
