Clutchs
Old Apr 2, 2003
Lakkaida's Avatar
Lakkaida is an unknown quantity at this point
Clutchs
any one any hook ups for a performance clutch for our cars.
EX 1.7 Vtec
i have read and did research on ACT clutchs looks like same clutch is used from older civics b16a SOHC
anyone with a new clutch and flywheel?? lets hear ur 2 cents
Old Apr 2, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
its the same for 6th gen....
Old Apr 2, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
If that's the case then the engine is D16Y8 ( I think, I'm sure it's D16Y something.). B16A is the 99-00 Si engine code which I'm fairly certain none of the parts from B-series engines would cross over to D.
Old Apr 2, 2003
Lakkaida's Avatar
ight so witch company should i go with ACT? Neuspeed N2?
anyone have a stage 2 or stage 3 clutch installed and running with either an ultra light flywheel or atleats lightend flywheel??
Old Apr 2, 2003
CarbonFly's Avatar
Talk to AdamOSU, he has a new clutch and flywheel
Old Apr 3, 2003
Lakkaida's Avatar
anyone have a hook up for clutchs?
Old Apr 22, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
About wt vs. dry. I spoke to a venom representative and he told me that the dry kits were actually designed for fuel injected cars. Reason being that the wet kits will not distribute the fuel evenly over all 4 cylinders unless you are using a direct port nitrous kit. The wet kits were actually first designed for carburated cars.
Venom's kit wires up to all four of your injectors adding more fuel as necessary. It also has a sensor to detect whether you are leaning out and will automatically shut off if it detects this.
Hope this helps.
Old Apr 22, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
wrong topic chick
Old Apr 22, 2003
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
too light of a flywheel and the torqueless wonder (our cars) looses even more torque
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
