question about the Throttle-Body Heater Bypass
Old Feb 28, 2003
no's Avatar
no
no is an unknown quantity at this point
Im was just wondering whats the advantich of doing the throttle-body heater bypass?
Old Feb 28, 2003
Ike's Avatar
Ike
Ike is an unknown quantity at this point
I've always wondered the same damn thing. I live in MS so I really dont need it, but whats the point if there is no benefit???[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 28, 2003
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
if you live in a hotter climate(ie az, socal, texas) it MAYBE helps if you remove it because it doesnt heat the throttle body(therefore not heating the intake charge).....thats the idea anyway.
useless mod. doesnt and will not do any thing in terms of performance, dont waste your time.
Old Feb 28, 2003
cambo's Avatar
I wish I was asian
in colder climates its needed. warmer climates can bypass it. reason for it is because in colder climates water in the air can freeze on/around ur TB, sometimes keeping it from turning. thus you could be stuck on the gas when you need to stop. there was a thread about it somewhere around here by noodleboy i think. Very Enlightening Post by n00dleboy
EDIT: maybe i'm thinking of something else....
Old Feb 28, 2003
Ike's Avatar
Ike
Quote
[hr]Originally posted by: SOHCScreamer
useless mod. doesnt and will not do any thing in terms of performance, dont waste your time.[hr]
Appreciate the advice
Old Feb 28, 2003
Logan3024's Avatar
that has to be the lamest DIY i have EVER seen!!!!! Whats the point of doing that besides wasting time.
Old Feb 28, 2003
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
the point of doing this is so that nice expensive 'cold' air intake you bought will actuly let in cold air. other wise the air is cold until it gets to the hot throttle body thus making the colder, denser, more benificial air into hot, thin and not as powerful air. just my 2 cents
Old Feb 28, 2003
Logan3024's Avatar
what 1.2 more hp?
Old Feb 28, 2003
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Quote
[hr]Originally posted by: CrazyCakes
the point of doing this is so that nice expensive 'cold' air intake you bought will actuly let in cold air. other wise the air is cold until it gets to the hot throttle body thus making the colder, denser, more benificial air into hot, thin and not as powerful air. just my 2 cents[hr]
Yeah, that's pretty much the idea behind it. And as for it being a useless mod, if you think so....then don't do it. It's just that simple. What's the purpose of the throttle cable adjustment DIY? It's not like you get more Hp or better performance. But I wouldn't call it a useless mod because it does help a bit by not having to push the pedal as far before you get a response.
Yes, in some cases this will restore a little bit of power that is lost when the air is heated up. As stated before in some of the answers in the DIY. If you have a CAI, the heat will transfer and heat up the pipe, which takes away some of the few horses that you gain from the CAI. If you pessimists would have actually read the DIY, you would already know this because it explains the concept and states that you will get no large gains. Common sense works too....
Old Feb 28, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
hmmm thats a good post!!!
INJEN
Old Feb 7, 2004
pheaton's Avatar
A descendant of 2k1civic.com
I actually think that during the summer when it's like 105 to 110 degrees in some parts of the world, this mod might .. Might . . MIGHT. . gain you 1HP. But don't count on it.
This heater though I'm guessing only heats the air when it's needed? Meaning that it's only going to do something during the winter, during the summer it's not going to make the air even hotter.
Old Feb 7, 2004
cwick187's Avatar
cwick187 is an unknown quantity at this point
Your not going to tell the difference no matter how hot/cold it is outside...Don't waste your time...I tried it...Didn't work, so I put everything back together.
Civic15
18
Sep 19, 2017 07:48 PM
MrOldskool
Aug 18, 2015 09:58 AM
civic98?
Aug 13, 2015 01:32 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
