Maximizing 7th gen fuel efficiency
Old Jun 9, 2017
civicenthusiast's Avatar
civicenthusiast is an unknown quantity at this point
Question Maximizing 7th gen fuel efficiency
So, I have a 2005 civic LX, which already gets pretty good MPG, but I'm wondering how to maximize it.
From what I understand there isn't a whole lot you can do to increase MPG. There are obvious things like decreasing weight and changing driving habits, regularly checking tire pressure and having good tread. I see mixed messages as far as modifications that can increase MPG.
Like the K&N 33-2192 High Performance Replacement Air Filter, where people say it has increased their MPG, where as others will say the difference is negligible.
As far as performance chips, some people say they work others say it's a gimmick that does absolutely nothing.
I was under the impression that increasing your HP meant you sacrifice MPG, especially for those that don't drive on the highway. Is it best to stay stock or try to increase your HP to increase MPG? I want to know peoples experience with this.
Old Jun 9, 2017
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Maximizing 7th gen fuel efficiency
Get rid of the ac system and power steering. Get rid of excess electronic accessories so they dont make the alt work hard. Convert to a manual transmission, auto trans wastes engine power on the fluid coupling inside the torque converter specially taking off from stops. You can also make your car more aerodynamic by fabing body panels, and covering the whole bottom of the car so air flows freely.
Old Jun 9, 2017
Lol my main question is if it's better to stick to stock or to try and increase HP. Because I thought increase in HP = decrease in MPG.
Old Jun 9, 2017
Disagree on AC and PS. I want some modicum of comfort.
Re AC use, the car is probably more aerodynamic at highway speeds with the windows rolled up, to equal or greater than the loss due to use of AC.
Make it light, aerodynamic, and decrease rolling resistance as much as possible
change habits.....change mindset
Goggle
hypermiler
ecomodder
Old Jun 10, 2017
mac25's Avatar
Dr Krieger of Modification
More horsepower means more air through the engine, more air means more fuel to balance the Air to fuel ratio.
The only way to make power is to run
-High compression
-boost
-NO2
All of which run more air and require more fuel.
Old Jun 11, 2017
After installing my crower stage 1 cam, I saw increase in MPG, I need stay less in the gas pedal to achieve same acceleration. Reach speed faster
But people that puts the cam wants to stomp more in the gas. That could negate the gains, plain and simple.
Old Jun 16, 2017
GusBuz's Avatar
I always average 30mpg +-2 mpg per tank. Im very happy with that..
I want the crower cam
Old Jun 16, 2017
CharlieDee's Avatar
Grey hair
CharlieDee is an unknown quantity at this point
Driving it like it's stolen still gets me 35-38mpg in my very slow and underpowered 01 LX Coupe. The trick is knowing it's slow and not trying to go fast, though on the freeway the cruise is set at 80
