2004 Si Spark Plug Change
Old Apr 20, 2014
NeoSi's Avatar
NeoSi is an unknown quantity at this point
Which do you guys recommend? Car runs fantastic but is hesitating a bit from 2nd gear on. Clutch is fine and I'm getting great gas mileage. Just want the gears to not hesitate once I've shifted.
Old Apr 20, 2014
Re: 2004 Si Spark Plug Change
2.0 Si gets either
IZFR6K-11, NGK
or
SKJ20DR-M11, DENSO
BTW these are 100,000 mile plugs.
Old Apr 20, 2014
cja3455's Avatar
cja3455 is an unknown quantity at this point
Denso iridium long life plugs are the OEM. You can also try to clean the air filter and throttle body and lubricate the cable, use some bg fuel system cleaner and sea foam it
Old Apr 20, 2014
NeoSi's Avatar
Are
Originally Posted by ezone
2.0 Si gets either
IZFR6K-11, NGK
or
SKJ20DR-M11, DENSO
Are both of those iridium?
Could worn out plugs cause hesitation directly after shifting?
Old Apr 20, 2014
Originally Posted by NeoSi
Are
Yes and yes,
but I kinda doubt worn plugs are the issue unless someone put cheaper plugs in it at some point.
Fouled plugs, sure.
Carbon tracked, maybe.
Coil issue, could be.
Not worn. Precious metal plugs don't wear appreciably the way standard plugs did. IMO
There are also other possibilities that can cause hesitation too.
thana
Jun 15, 2020 07:05 PM
vtecbrah
May 31, 2015 01:24 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Micks2K1
Dec 10, 2001 07:11 PM
