03 civic on rev limiter
Old Sep 24, 2013
dragnlady5028's Avatar
dragnlady5028 is an unknown quantity at this point
03 Honda civic vtec- when hit 4000 rpms pulling a hill in the mountains the rev limiter comes on. Concern is intermittent. only trouble code is cat efficiency. Can a cat cause an intermittent concern like this or is there a sensor that tells the rev limiter to come on? rev limiter works normal in park etc as it should
Old Sep 24, 2013
Re: 03 civic on rev limiter
Is the oil full?
Is it a rev limiter, or is it an exhaust restriction?
On your hills, will it go faster if you back off the gas pedal a little bit?
On a flat road....Can you accelerate wide open throttle through 1st and 2nd gears all the way to redline?
How bad is the cat? Does it rattle or anything?
If the cat substrate (guts) came apart, pieces could move downstream in the exhaust and bounce around get lodged, causing random clogging (excessive backpressure). That sure could act like a rev limiter of sorts.
/random thought
//lunch minutes are over
Old Sep 24, 2013
My daughter checked her oil level and it is a quart low. We will add oil and try that first. Thank you
beneditti
Jan 15, 2016 12:31 PM
Fastfebur
Apr 26, 2015 11:57 PM
Blaster30
Apr 22, 2015 12:21 PM
locozoko
Nov 8, 2001 06:33 PM
Guy01
Nov 6, 2001 03:25 PM
