Flywheel question
Flywheel question
Hey, nw member here.
I am replacing the clutch on my 2002 honda civic si(canada), was curious if it was absolutely necessary that I replace the flywheel this time around or would it be fine if I just machined it again.
Re: Flywheel question
I don't touch the flywheel unless it is damaged. If there is damage, then I replace.
Ever since I started wrenching, I have had better luck leaving it alone than machining.
Checked specs: All I see is a runout spec.
Machining this flywheel is not recommended.
C&P from the Honda site:
If the runout is more than the service limit, replace the flywheel, and recheck the runout. Resurfacing the flywheel is not recommended.
OptimisticWay
46
Oct 15, 2015 02:16 PM
martinsmartin
Aug 15, 2015 07:34 PM
JetsterDajet
Aug 15, 2015 08:07 AM
