power increase going with a CROWER STG-1 cam with stock everything else
Old May 3, 2012
pmjr0987's Avatar
pmjr0987 will become famous soon enough
in the maintenance section i have a thread about me doing a small cheap rebuild on my D17a2. doing new rings and new valve seals and re seating the valves. thats about it.
i have the cam sitting on my work bench so this upgrade will cost me zero additional labor.
what if any gains could i realistically expect with this cam on a stock intake/exhaust car???
I might be willing to do a set of headers but i would be running a stock cat-back and stock intake.
id like some more power and i do not want to sound like a ricer flying down the street with a whopping 140 or so hp so i want it to sound as stock as can be, but what HP would i be looking at from the stock 127?
also, how is the torque curve? this engine can use some serious help in the low rpm so im hoping the stg 1 cam can add some real world gains down low, while allowing the motor to breath out some more horses on the top end
Old May 3, 2012
MindBomber's Avatar
Live for the Twisties
Re: power increase going with a CROWER STG-1 cam with stock everything else
Have you read the stage 1 cam thread?
I believe, one of the dynos I have posted on the final page of it shows around a 15hp gain on a car with only an intake.
Old May 3, 2012
pmjr0987's Avatar
i was looking around and saw nothing about it, thought it was weird ill go back and recheck
Old May 3, 2012
I should prolly dyno mine, but then again, I have an intake and full exhaust system, and I'd finally put my AEM FI/C to good use.. lol.. I doubt that you'd reach 140 with just the cam and a header.
If I remember correctly, a stock D17A2 with a manual tranny dynos at about 110 at the wheels.
The dyno sheet I saw was about 125whp, but it was a D17A1 bottom, -a2 head, intake, header, and a catless exhaust sytem.
Realistically, with just the cam, you'd probably get into low 120's.
Old May 3, 2012
maxtierney's Avatar
EM2ti
I'm there with you, I'm trying to get a dyno done too.
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 07:40 PM
plastikman
Dec 13, 2001 03:18 PM
civiccowboy
Dec 7, 2001 07:07 PM
