02 civic lx D17A1 which wire is my signal wire
Old Nov 29, 2011
02carbon_civic's Avatar
02carbon_civic is an unknown quantity at this point
i have a 2002 honda civic lx D17A1 im looking for my signal wire from the o2 sensor so i can hook up my air to fuel ratio gauge someone please help i was hold it was the black wire is that true ?
thanks for your help and your time
Old Nov 29, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
Re: 02 civic lx D17A1 which wire is my signal wire
uhhh correct me if im wrong...but doesnt our cars use a narrowband? i thought you could only add a wideband sensor and put a gauge on that. like the AEM UEGO
Old Dec 1, 2011
it doesnt matter but the wideband is betterperformance and a better reading
Old Dec 1, 2011
if you tap one of those cheesy and useless a/f gauges to your factory sensor (wide or narrow band it doesnt matter), you will screw up your engine. the voltages from the sensor to the ecu will change, and the ecu will make wrong adjustments to the engine fuel trims. the only way to safely add an a/f gauge is with a separate O2 sensor welded into the exhaust pipe (wideband if you actually care about accuracy, narrowband if you just want a light show).
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
shaejb15
Apr 26, 2015 07:44 PM
alexkharden
Apr 23, 2015 07:13 PM
Fastfebur
Apr 22, 2015 01:37 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
