Clutch and flywheel
Old May 17, 2007
speedingslowly's Avatar
speedingslowly will become famous soon enough
Clutch and flywheel
sooo, long story short I pwned my tranny. So i have the tranny straight, but i need a clutch and flywheel, I dont want a too agressive clutch, and I also need a flywheel. My car is a 2001 civic ex 5 speed, could someone let me know a good combo to get and where at?, thanks
Old May 17, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
Re: Clutch and flywheel
dezod offers stuff... what kinda of clutch and flywheel do you want... and i assume you know what changing the flywheel does... i recomend the excedy for a direct replacement... thats what i have on mine... its the stage one steet/comp. clutch with disk and i just reflnished my flywheel... if you install it urslef... and have any questions... i have done it myself... feel free to askquestions...
Old May 17, 2007
speedfoos's Avatar
I have the Exedy Racing Stage 1 clutch and lightened flywheel. I absolutely love it, and my engine only has your standard bolt-ons (for now).
Here's the thread I made when I was researching it and then bought it:
Researching Gripforce Exedy set-up
Here's the thread I made when I got it and installed it:
Speedfoos' Gripforce Clutch
I'm really happy with it and know a couple other folks (Haysoos on d-series.org is one) who bought the same setup and also love it. The whole shebang cost me $425 shipped.
Oh, gsniper666, I still like the Ingall's stiffy now that its installed correctly. I've had it on for about 2 weeks now. It feels pretty much the same now as it did when I put it on wrong. Wheel hop is mostly gone now, and that's spinning them from a 5K launch, with a shriek in 2nd and a little chirp in 3rd.
Old May 17, 2007
dezod's Avatar
7thgen Power Maker
Let me know if I can help with some clutch options. Car boosted? What's it used for? DD I presume?
Old May 17, 2007
actually car is bone stock, my only plans are to do a few bolt ons(intake, exhaust/header, cam), but i know that a lighter flyhweel will increase engine response, my main concern was if there is any negative issues associated with a lighter flywheel which will effect driveability, and as for the clutch i dont want anything harsh, preferably close to stock. and yes, this car is my dd.
Old May 17, 2007
speedfoos's Avatar
Not really, just try not to go under 11 pounds. Its makes gettin going from a stop a little more difficult. You have to rev a little higher as you have less inertia (especially on those 7lb Fidanzas) , but then again, there are several folks who swear by the 7 pounders. Since you're staying with mild bolt-ons, and a its a daily driver, stick with a full-face organic (no 4 or 6 puck discs), and maybe a lighter flywheel. There are theories out there that a lighter flywheel lowers your gas mileage because there isn't as much inertia behind a lighter flywheel so you have to stay on the gas more to keep the same speed. If that's true, I haven't noticed it on my 11 pounder. Everyday really isn't Earth Day.
Old May 18, 2007
dezod's Avatar
7thgen Power Maker
Stick with an 11lb Flywheel unless you want hardcore all motor status. The downside to the lighter flys is slower coming out of the hole.
Close to stock, I would go Stage 1 Comp Clutch (not to break the bank)
http://www.dezod.com/pd_competition_clutch_stage.cfm
If you adiment on a full faced disc, Stage 2
http://www.dezod.com/pd_competition_clutch.cfm
Exedy organic
http://www.dezod.com/pd_exedy_organic.cfm
These are the 3 cheapest, closest to OE and still have some value to them.
Old May 18, 2007
thanks guys, i just made my appointment today so on mondya they r gonan diagnose/fix my tranny(they said 1500 : ( ) oh well, i dont get mad at stuff like that tho, so i guess ill just splurge and buy the flyhweel and clutch in about a month, from dezod, btw i love the site, keep it up.
Old May 18, 2007
dezod's Avatar
7thgen Power Maker
Thanks! Lemme know when I can help ya
Old May 23, 2007
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
A new flywheel would be a huge waste of money, you're better off spending that $$ elsewhere.
Old May 23, 2007
speedfoos's Avatar
And why is that?
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
beanhead
Sep 24, 2015 12:04 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
