Smallest Mod blew me away!!!!
Old Jan 7, 2007
DJ GEE's Avatar
DJ GEE is an unknown quantity at this point
Ingalls engine torque damper. let me tell your guys this. Ignalls kicks man this is the best mod I ever put on. This is for anyone who says a D17 has no *****. Throw this little shiny piece on there and boom. I mean with CAI Apexi Exhaust Denso Iridium Plugs Strup Headers and Randon tech cat. Ignalls just put the icing on the cake. Thanks Dezod.
Old Jan 7, 2007
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
sweet, i just put in the energy suspension polyurethane motor mounts and got a lot of good results from that dont have the engine dampner yet though.
Old Jan 7, 2007
TeLLy's Avatar
Yes, it's an Acura EL
That's the good ****, I love my Ingalls engine damper.
BTW you're the second DJ Gee I've encountered on a car forum. Just thought I'd mention that.
Old Jan 7, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
160? Think it's worth it? I'm going to stick with the D17 so I guess I should slap er on.
Old Jan 9, 2007
TRIZ's Avatar
So, do you need to get the polyurethane mounts with the dampener, or are they optional.. and whats the benifit exactly?
Old Jan 9, 2007
skipbarber's Avatar
^ i would do one or the other, both is overkill IMO. Not to mention an incredibly rough idle quality.
Old Jan 9, 2007
kasimmmmm's Avatar
i've read a lot of good reviews about it.... nothing bad. Must be worth the $$
Old Jan 9, 2007
TeLLy's Avatar
As per the Ingalls website:
Benefits
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against
the hood and frame.
For sure dude, I believe we talked about this when we met up too. I'm not entirely sure, but I believe you'd be able to use this one, pure JDM bling:
A&J Racing :: Engine :: Integra & RSX (DC5) :: Spoon Engine Torque damper - Acura RSX DC5 02-04
Old Jan 9, 2007
i5r's Avatar
i5r
i5r is an unknown quantity at this point
can someone tell me where i can get it ???
toronto area please!!!
Old Jan 10, 2007
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
just makes your car feel shakey in idle but other than that, you get better response.
Old Jan 10, 2007
TRIZ's Avatar
Just order it off the net? I googled it and here was one of the first few hits with the one for our civic: Ingalls Stiffy Engine Torque Damper :: NIPPON POWER Look around and you might find a better price.
Old Jan 10, 2007
TRIZ's Avatar
Looks like they got the spoon ones for DC5, ITR, B16's, and the EP3's. I wouldnt mind being the first one to take a Spoon dampener and fitting it in a D17 em2, 200 bucks is kinda steep- plus you'd probably need the mounting hardware for the Ingals in order to modify the spoon hardware to fit, might even be able to use the Ingals hardware with the spoon dampener
Old Jan 10, 2007
mikecivexxx's Avatar
mikecivexxx is an unknown quantity at this point
How hard is one to install? Scale from 1 to 10... 10 being the hardest.
Old Jan 10, 2007
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
yeah kinda wanna know how hard the install would be. kinda intersted in getting one
Old Jan 10, 2007
TeLLy's Avatar
There are tons of articles on this thing just on the forum, just have to search people. It's about a 3 in terms of install difficulty, and in Toronto you can order one from BattleEndless for about $200CDN all in.
Old Jan 10, 2007
TeLLy's Avatar
It's been done and yes the Spoon damper will physically fit with the Ingalls hardware.
Old Jan 10, 2007
texas-civic's Avatar
texas-civic is an unknown quantity at this point
does it matter if its a ex or lx...?
Old Jan 10, 2007
ronaldo9's Avatar
Yes, if you have an EX I'm not sure if it will fit bc the ABS box is in the way unlike the LX/DX. Plus if you have a strut bar it won't fit unless you have longer top mount bolts like a tein upper mount bc there won't be enough thread left on the bolt with a strut bar and stock top mount.
Old Jan 10, 2007
red05's Avatar
red05 is an unknown quantity at this point
How is the vibration in the car? I've been in some cars that vibrate really bad with stiffer mounts and I don't want my car to be like that.
Old Jan 10, 2007
2k3civicSSM's Avatar
2k3civicSSM is an unknown quantity at this point
i think this is a very good mod, wish i could find the video but it was a d17 on dyno and holy **** that engine moved around a lot more then i thought.
Old Jan 10, 2007
TRIZ's Avatar
Hmm, know of a place where I could get the ingalls hardware w/o the stiffy? Also, who did it?
Would it work with tein SS w/ pillow mount... and how about with the P/U AND strut bar?
Old Jan 10, 2007
blouisgod's Avatar
Life Begins > 6800rpms
I have the damper and I liked how it felt, but it made the whole damn car shake, especially the steering wheel - so bad I had to remove it. I havent worked on putting it back on yet, maybe soon. Any ideas on how to remove the vibration?
Old Jan 10, 2007
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Correct me if I'm wrong, but doesn't that kind of defeat the purpose of having liquid-filled engine mounts?
Old Jan 10, 2007
DJ GEE's Avatar
Just add some bushings to the mounting bolts. They give you two with the hardware. I just added one to the top of the bolt and one where the nut is and my vibration is there but minimal.
Old Jan 10, 2007
ronaldo9's Avatar
Yes it works perfectly with a tein ss mount and a strut bar bc my buddy has an ES1 with tein ss and neuspeed strut bar and the bolts are long enough to fit both the strut bar and torque damper.
Old Jan 10, 2007
Yea only part that sucks is with the neuspeed bar and the stock strut housing i dont have enough thread on em, but if i get one i might see if ican make it fit...
or i wonder if it be possible just to replace that 1 bolt with a longer one..
Old Jan 10, 2007
blouisgod's Avatar
Those things got ripped apart on the first run LOL. Maybe some o-rings from garden hose would work better.
Old Jan 10, 2007
dezod's Avatar
7thgen Power Maker
Dezod Motorsports. Ingalls "Stiffy" Engine Torque Damper-Civic 01-05 (See Notes**)
Old Jan 10, 2007
TRIZ's Avatar
He has the tein SS, but does he have the pillowball mounts? I'm in the process of ordering the SS's, so unfortunately I cant go eyeball it. I think they eat up a considerable amount of thread no?
Old Jan 10, 2007
dezod's Avatar
7thgen Power Maker
A minimal vibration will be encountered, but not that severe. You can adjust the sensitivity of the damper, which if set more aggressive will cause lots of vibes. Otherwise, some dynamat will work fine.
