intake
Old Dec 16, 2006
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
intake
ok.. ive seen/heard of eveyone doing thing with intakes, and most quite frankly scare me... i mean.. wow.... ok... here is my question...
the resonaor and airbox hold air for the engine while no under exceleration... which is why stock airboxes yield more torque... my question is... what if the resonator is taken out... yu leave the stock intake manifold, but take out the filter, then add an aftermarket intake head.. my other idea would be to make an intake box to hold, when not under acceleration, the air, but make it completey open... im thnking about giving it a try and using an aem intake head... any thoughts???
i'm trying to retain torque and maybe add a little of hp.. nuttin big, just a new project to see if gains can be yielded... plus i have the ability to custom fab the parts...
Old Dec 16, 2006
skoot's Avatar
skoot is an unknown quantity at this point
"yu leave the stock intake manifold, but take out the filter, then add an aftermarket intake head.."
How are you going to filter the air with not filter? Leave it stock you will be much happier you did. Intakes do nothing for our cars except make it loud
Old Dec 16, 2006
gsniper666's Avatar
an aftermarket head refering to a cone type head
Old Dec 16, 2006
Maverick_1337's Avatar
Maverick_1337 will become famous soon enoughMaverick_1337 will become famous soon enough
i know what you mean but remember it will be sucking hot air
Old Dec 18, 2006
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
dont take out the filter. from what you are telling us, i say you should just go by you a short ram intake. and plus, buying a aftermarket intake system or whatever will give you only 1 or 2 hp gain. dude that really sucks. if you dont feel like wasting so much money on a intake, just get a k&n filter and slap it on there.
Old Dec 18, 2006
shmik1's Avatar
I enjoy the sound of my typhoon and I've heard there can be a 1-3mpg increase.. Im not losing any mileage thats for sure.
Old Dec 19, 2006
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
if you simply put on an intake without a FULL exhaust on your civic, you will actually lose power. I have seen this happen on 2 civics.
I dont know how much engine knowledge you have, but your engine is basically an overglorified vacuum. put your hand over your intake and you will feel it sucking. that said, regardless of whether you are accelerating or not, the engine is ALWAYS sucking in air. regardless of whether there is "reserve air" sitting in the intake box or not, your engine will get the air it needs, or it will stall.
Old Dec 19, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
as you may know, it make really no difference except throttle response (i assume thats what you mean by torque).
anyways i messed around with mine and built my own intake for free. kept the stock air filter box and replaced with k&n (really makes no difference) and connected a straight pipe from there to the hole near the battery, replacing the resonator. now that that is done, i messed around more for some cooler air. i slotted holes where the fog lights would go and connected bendable piping from there (with zip ties) to the hole near the battery(btw, dont connect the two pipes together cuz when it rains, water might get sucked in and hidrolock).
sounds pretty neat, but as for the throttle responce, i assumed it improved if any. i also assume that the cooler air would help with power.
overall just sounds and since it was free project, what the hell...
UltraHDGames
Jun 8, 2016 05:16 PM
ThatGuy913
Nov 9, 2015 06:31 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
