get a dc race header, but comes the problem, need help!
i installed the dc race header in my 04 ex, but after that i found that the MALFUNCTION INDECATOR LAMP turns on. is it normal just because that stork cat has been removed? how to turn off that lamp. thanks everyone.
if its a resonator or a so called highflow cat from ebay then you will need a o2 simulator to turn off the cel. go to www.casperselectronics.com they will have what you need. otherwise there has to be an actual cat in place
Jspek Inspired
Originally Posted by xiaosa
Thank You.
So Why Lots Of Menbers Have The Problem With The Race Header....
Is The 04 Ex Model(the Ecu) Different From 02 Or 03 Because I Seen Menbers Have To Get A 02 Sim To Turn The Cel Off.
I Am In Canada So I Cannot Pass Air Care With The Race Header.
I Did Installed The Header In My Auto Em2.
Ps: I Called Dc Sport And They Said The Cel Turns On Is Normal, And Doesnot Affect The Perfermance At All.
I Am Not A Native Speaker So My English Is Not Good...hope You Understand Waht I Said.....
either an o2 simulator from www.casperselectronics.com or put in an actual cat and not a test pipe/resonator
im at work right now so i cant give you the link for the o2 simulator mod that will definately take off that cel light but when i reach home ill post again with the link...(it has pics as well so i shouldnt b much of a challenge)
man i cant believe i forgot the add the link i spok of in my previous post
https://www.casperselectronics.com/M...ory_Code=honda
the car is different. your probably using a bit more gas and dont have as much power as you could.
would i need a 12 inch or 24 inch or 36 inch?
i dont know exactly where th megan relocates the sensors. if its like the ex exhaust then the front o2 needs to be extended about 12" and the rear about 24". i extended them myself. just make sure not to mix up the 2 white wires and be sure to solder them and put soem cold shrink tape on or heat shrink tubing. do you have the megan parts on now or are they awaiting install for the sim? if you have them on now are you throwing a cel?? if you have them on now and arent throwing a cel then you probably dont need the extended wires becasue they already fit. LOL
You will feel gains yes but nothing to brag about. Yes the sound is louder. Honestly, anything is better than stock since the stock pipes are so skinny but id' just get a shorty header to stay emissions legal.
Originally Posted by R3DL1N3
just get spark plug defoulers from autozone and drill one of them out with a 1/2" drill bit. then put them together and hook it up to your o2 sensor.
Supramk3
Jun 11, 2015 11:13 AM
EK_Eddy
Jun 6, 2015 07:31 PM
