steering wheel question
Old Feb 1, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
ive searched thouroughly(sp?) and ive found out that the rsx and the ep3 steering wheels will work for our cars but the rsx steering wheel will require some cut and soldering of wires which i dont want to do b.c i would like to keep my wires intact if i have the need to switch bak to my stock steering wheel. im not sure bout the ep3, if they require the same things unless they are a complete swap with absolutely no modifications? any help with info on this and any other steering wheels that will work too that would help a bunch. thx. links to discussions of these are welcomed.
Old Feb 1, 2006
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
get a ep3 wheel...its a bolt on and you can keep your cruise if you have an EX.
Old Feb 1, 2006
TheSmuggler's Avatar
Considering the USDM si and rsx wheel are almost exactly the same, I can't see how you'd have to do any wire changes.. unless someone dosen't know the difference between dual stage and single stage airbags.
Old Feb 1, 2006
crazyasian's Avatar
cause i heard the plugs are different for the rsx and from our cars.
Old Feb 1, 2006
diskreet's Avatar
(if its true) thats why they make wire strippers, heatshrink, soldering irons, and electrical tape
Old Feb 2, 2006
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Does this mean I wouldn't be able to keep the cruise on my LX?
Old Feb 2, 2006
ncirom2003's Avatar
im sure alot of people dont, messign with the wiring on those and deciding what to put where is NOT something a beginner should do. probably even a person who understands them.
Old Feb 2, 2006
crazyasian's Avatar
as i said in my first post that i dont want to modify or even touch the wires b.c i still want to use them later on if i have to. so im guessin the ep3 steering wheel works w/o any modifications?
Old Feb 3, 2006
Well there's quite a few people on here that have had the rsx steering wheel... inclluding Phaoh and ruffryder009. You may want to contact them.
Old Feb 20, 2006
CraigW's Avatar
Thread Hijack !!
Anyone know if the EX to LX steering wheel swap (wheel only, keep my airbag) is easy/possible ??
I miss having a leather wheel, And a wheelskins cover is tough to do and look as good as original equipment.
Thanks,
honda200192
Suspension
Oct 27, 2019 12:23 PM
honda200192
May 31, 2015 05:57 PM
Optimus34
May 25, 2015 11:52 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
