underdrive pulleys
Old Aug 23, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
underdrive pulleys
ok there are underdrive pulleys for the alternator, the crank, power steering pulley, and the A/c?? im not sure about the A/c one. so any thoughts about this? did i miss anything?
Old Aug 23, 2005
frdeffscrbrd's Avatar
frdeffscrbrd is an unknown quantity at this point
unortdox has the full pulley did but it doesn;t come with belts, go with the aem pnes i was told by my friend who own a shop out here in rosenberg that the UO pulley are for racing because the pulley on top is a little too big and it makes a olt of noise when the car is on and u dont get the belts. BUt with the aem ones u don;t get the noise and the u get the replacment belts with it. Just stick with the Aem Tru Power pulleys
Peace,
Scoreboard
Old Aug 24, 2005
crank pulley = very bad idea
Old Aug 24, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
never change out your stock crank pulley.
Old Aug 24, 2005
FreshMaker's Avatar
FreshMaker is an unknown quantity at this point
why is it a bad idea?
Old Aug 24, 2005
http://www.7thgencivic.com/forums/sh...d.php?t=151653
Old Aug 24, 2005
MajinB's Avatar
ok but did i miss anything else? is there an a/c pulley?
Old Aug 24, 2005
tuner04civic's Avatar
spell check pwns you
well alternator and power steering come in aem pulley kit along with the belts....anyone know where to get aem replacement belts?
gearbox-good thread on that i know i will never change the crank pulley...which i tend to see around everywhere...mostly ebay..good job
ac pulley....i have no clue on that one....never heard of it
Old Aug 24, 2005
^^^ you can probably get a replacement belt by contacting aem. you can goto auto zone and ask them for a belt.
Old Aug 24, 2005
thanks
Old Aug 24, 2005
messiah's Avatar
messiah is an unknown quantity at this point
get the UO racing crank pulley. that's all you need to change. don't change the alternator and p/s pulley.
Old Aug 24, 2005
^ no dont change the stock crank. search around for crank pulleys and see what others say
Old Aug 24, 2005
messiah's Avatar
i have used UO crank pulleys on all of my previous civics. never had problems. im currently using the UO crank pulley on my 05 civic. i have 15k miles. so far so good! best mod for this car so far.
Old Aug 24, 2005
You'll have problems later don't worry.
Old Aug 24, 2005
messiah's Avatar
as soon as i have problems, you'll be the first person to know.
Old Aug 24, 2005
let me be the second person to know.
Old Aug 24, 2005
messiah's Avatar
ayt!
Old Aug 24, 2005
familycar's Avatar
you WANT to use overdrive pulleys on the alt and power steering if you do use a crank pulley, the reason fo rthis is because you will underdrive the accesories to omuch if not. the overdrive pulleys make up the difference that the underdrive crank pulley uses. and gearbox is right do not use a crank pulley that is not dampened or has a harmonic balancer integrated. if you do you will see problems occur in the future
Old Aug 24, 2005
ya thats right. A smaller crank pulley will severely underdrive all accessories. Also our stock pullies have the harmonic damper to suppress crankshaft vibrations.
Old Aug 24, 2005
hmm...it would be nice if it was safe to have a crank pulley for our cars. =/
Old Aug 24, 2005
MajinB's Avatar
no one knows if there is an air conditioner pulley? little help?
Old Aug 24, 2005
no there isn't
Bonobo
Oct 2, 2015 06:58 PM
AffliictiioN
Sep 16, 2015 02:21 PM
stank
Sep 16, 2015 07:40 AM
WaryDriver
Aug 8, 2015 05:08 PM
