Maximum HP from a D17A1?
Old Jul 15, 2005
  #31
start off with the basics and look around the site. Tighten the throttle cable cause I bet its already loose from the factory. That will make the gas more responsive. I know for the tranny you can get stuff like short shifter, bushings, and some other stuff. Not sure exactly cause I have an auto. It has some decent pull but also alot of mods. Check out the hyper voltage system type MR from optauto.com its $180 but helps acceleration a bit. You just hook to your battery. The thing that made the most power ~10whp is port and polishing the head. Its expensive tho but dealer will never know.
Old Jul 16, 2005
  #32
ajhdragon's Avatar
7thgens official a$$hole
check out the new full crower stroker kit its like $4500, but 14:1 compression add that to thier new cam/valves and some arp bolts to hold it all in and you got yourself one powerful d17 if yo uwanna spend the cash for that go for it. and for regular maintnence dealer will never know.
Old Jul 16, 2005
  #33
brandon4455's Avatar
brandon4455 is an unknown quantity at this point
I'd like to keep the price somewhat below a new high horsepower engine, since that would defeat the purpose and whatnot.
carid
Nov 7, 2015 01:46 AM
JMKendrick
Sep 16, 2015 06:17 PM
Juanb24
Sep 15, 2015 12:39 AM
MamaBear2015
Sep 4, 2015 09:04 PM
bambuski
Jan 26, 2002 04:36 PM
