axle back hitting sway bar......
Old Jul 5, 2005
flyers27's Avatar
Broad Street Bullies
flyers27 is an unknown quantity at this point
Angry axle back hitting sway bar......
my axle back exhaust is hitting my rsx sway bar around turns. any suggestions? thanks
Old Jul 5, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
bolt your axle back a little tighter to the body itself. i mean where exactly is the exhaust hitting the sway bar? and are they sharp turns or wide ones? just wonderin.
Old Jul 5, 2005
flyers27's Avatar
it clanks around regular and sharp turns. do you mean tighten it up by where the rubber mounts are? how would i do that?
Old Jul 5, 2005
MajinB's Avatar
no i mean get more U shaped mounts and put them on the chasis. go to a mechanic and tell him the prob. either get rubber mounts that are tighter to the chasis-meaning the rubber is tighter so it swivels less, or get the U brackets, they will stop the whole thing from moving at all. just find a good place to put extra brackets.
Old Jul 5, 2005
flyers27's Avatar
still dont understand what your talking about..... the hangers that come from the chasis attach to rubber hangers which attach to the muffler. do i need tighter rubber pieces? or should i say less flexible rubber pieces.
Old Jul 5, 2005
MajinB's Avatar
yes less flexible rubber pieces. and what i mean it that bracket that holds you cat to your chasis. those things with bolts on them that hold the cat and piping. i can't really describe it any other way.
Old Jul 6, 2005
flyers27's Avatar
any other suggestions.
Old Jul 6, 2005
djmota's Avatar
get a piece of black good quality hose split it and hose clamp it to your sway bar. no more rattles
Old Jul 6, 2005
gh0st's Avatar
TAQUITOS!!!!
you didn't put it on backwards did you?
Old Jul 6, 2005
flyers27's Avatar
wont the hose melt? sway bar is on correctly.....as far as i know. didnt make any noise till i just put on the axle back.
Old Jul 6, 2005
djmota's Avatar
It wont melt as long as your pipe is not resting on it all the time. The temp of the pipe back there is not that high.
Or one step better is getting some cloth covered breather hose for a german car vw ect. the cloth cover will keep it from melting. < thats what i am using.
dc exhaust hangs really close to the swap bar.
Old Jul 6, 2005
robbclark1's Avatar
Retired suspension supermod.
DJmota is a winner
Old Jul 6, 2005
K20me's Avatar
Where can I purchase this "cloth covered breather hose"? I have a feeling that when I install my Progress rear sway next week that I will have a rubbing problem as well because I already had rubbing with the rsx rear sway. Thanks in advance.
Old Jul 6, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
Progress redesigned their rear sway so it wouldn't have issues with aftermarket exhaust, hope it works out for you, my sway came today but I wasn't here to sign for it
Old Jul 7, 2005
K20me's Avatar
Wow, didn't know that! Thanks man.
Old Jul 7, 2005
djmota's Avatar
thats good news I had to sell my progress bar a long time ago because it would not clear.
as far as finding the cloth covered hose you should look around for a local european auto parts place. or any aircooled vw shop. I would be willing to bet that the rubber hose will work fine. if you can't find the cloth covered stuff, for a couple of bux the rubber hose is worth a try.
Old Jul 8, 2005
flyers27's Avatar
a rubber hose would definately melt....dont you think. the pipe between he muffler and the cat gets very hot.
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
dinsum
May 28, 2015 09:30 PM
Rogelio Rey
May 24, 2015 08:30 PM
lildoo
May 9, 2015 09:44 AM
dragonsblood
Apr 27, 2015 12:28 PM
