High Flow cat
Old Jun 16, 2005
rutscivic's Avatar
rutscivic is an unknown quantity at this point
High Flow cat
i want a high flow cat...anyone know of any good name brand cats to get...and what price would i be lookin at???
THANKS
Old Jun 16, 2005
jttegx's Avatar
OMNES AD UNUM
random technology
carsound
megan (test pipe)
cusco(sp*)
check out vendors www.truehonda.com www.dezod.com www.robearracing.com and ebay
http://robearracing.com/cat_honda_civic_01032.cfm
i would do as much research as possible. some 'hi flow cats' throw check engine lights, some dont. some work better, some are legal, illegal, etc.
Old Jun 16, 2005
dezod's Avatar
7thgen Power Maker
Random Tech is a real cat, not a test pipe and will not throw a CEL.
http://dezod.com/pd_random_technolog...ertercivic.cfm
Purchase from an authorized distributor....
Old Jun 16, 2005
rutscivic's Avatar
Thanks
Old Jun 19, 2005
rutscivic's Avatar
wait what do you mean by CEL?
Old Jun 19, 2005
dezod's Avatar
7thgen Power Maker
Check Engine Light
Old Jun 19, 2005
rutscivic's Avatar
**** all of em will throw the check engine light BUT the random technology
Old Jun 19, 2005
dezod's Avatar
7thgen Power Maker
Megan will, Random Tech will not.
Old Jun 19, 2005
rutscivic's Avatar
could i just get a o2 sensor simulator?
Old Jun 19, 2005
dezod's Avatar
7thgen Power Maker
Yes but you will probably not pass emissions if your state tests.
Old Jun 20, 2005
rutscivic's Avatar
thanks DEZOD
Old Jun 20, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Megan doesn't have a cat it uses a resignator.
Old Jun 21, 2005
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
so what are the benefits of having a high flow cat, louder? more hp?
Old Jun 21, 2005
jttegx's Avatar
OMNES AD UNUM
same purpose of installing any other exhaust part. more power, air flow, larger pipes if neccesary. and yes, it could make your overall sound stage louder since theirs no restrictions besides a resonator on the catback. but if your running an hi flow cat and straight pipes with no resonator to the muffler, then its gonna get loud
Old Jun 22, 2005
will their be any hp gain with strait pipes highflow cat and muffler ? Will i gain tope end and loose some bottom end ?
Old Jun 22, 2005
will their be any hp gain with strait pipes highflow cat and muffler ? Will i gain top end and loose some bottom end ?
Old Jun 22, 2005
Honda2k4's Avatar
^ you would, but probably not much
im thinking of getting a high flow cat, right now i have an aftermarket header and cat-back exhaust. would a hight flow cat bolt right up with this setup? my car is an ex
Old Jun 22, 2005
dezod's Avatar
7thgen Power Maker
Yes sir. You will notice increased mid range and high RPM power.
Old Jun 22, 2005
Honda2k4's Avatar
im a little confused, whats the difference between a downpipe and high flow cat? are they the same thing?
Old Jun 22, 2005
dezod's Avatar
7thgen Power Maker
Downpipes are for turbo applications. They are attached to the exhaust discharge side of the turbo and usually attach to the exhaust system of the car.
A high flow cat is a high flow catalytic converter that converts unburned exhaust gas to safe elements and water. Cats are typically found on OEM downpipes and on all production vehicles, but are typically restricting. Hence why people want high flow cats. Less restricting.
Old Jun 22, 2005
kornsined's Avatar
I have a megan downpipe and I'm fairly happy with it. Faster rpms, higher rpm power, and more of a kick when vtec clicks on. I did this trick and have yet to get a CEL in a month and half. Although up here they don't do emissions tests YET. You will most likely fail with the fake high flow cats. Get random tech if you want a true high flow cat. BTW I've only noticed a small change in exhaust smell and it's very rarely that I smell it too.
carid
Nov 7, 2015 01:46 AM
jzhartman
22
Jul 23, 2015 10:42 PM
cizsak
Jul 21, 2015 03:39 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
silentz
Jul 9, 2015 08:16 PM
