clutch!
Old Apr 7, 2005
Civman500's Avatar
Civman500 is an unknown quantity at this point
Exclamation clutch!
check it my stock clutch has just over 55k miles on it, and its just about gone, should i just throw another honda clutch in or go with the Exedy organic one thats a step up from stock? plus i heard you should either get a new flywheel or get it resurfaced, is that true? if so who can resurface it for me? otherwise how much would a new flywheel run me?? if you can help me out lemme know, Thanks.
Old Apr 7, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
I will be getting my Exedy clutch installed next week or so and yes if you use you stock flywheel it needs to be resurfaced - any shop can do it that works on transmissions
Prices vary on flywheels my Prolite costed my $175 because i went through my friend's shop, normal is $250 shipped
Old Apr 7, 2005
flotsamm's Avatar
New clutch, pressure plate, throw out bearing, pilot bearing and get your flywheel resurfaced and you should be good to go.
Old Apr 7, 2005
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
get the exedy over stock its gonna be cheaper. You can get your flywheel resurfaced once, depending on who you get to install it either a transmission shop or the dealer. aftermarket flywheels range from 200-240, or at least my act 8lb. cost like 23x.xx from truehonda.com
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
