Clutch
Old Mar 6, 2005
exturbo6's Avatar
Cool Clutch
Whats the differance between the Exedy Organic Clutch, and Exedy Cerametallic Thin Clutch? Which would be the best for 9-10psi?
OK and i just tried finding out what the differance is between the ACT XACT Streetlite Flywheel, and ACT Prolite Flywheel. they are both the same but the prolite is 243and the streetlite is 216. thanks!
Old Mar 6, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
The difference is in the composition of the clutch disk itself. The organic clutch is composed of softer materials vs the Cerametallic which is semi-metalic. It follows the same concept of the different types of brake pads. You have Organic, Semi-metallic, and full metalic. With the organic, you'll have the feeling of the stock clutch, but with will hold up much better with the overstock clamping force of the new pressure plate. The Cerametallic is designed for more punishment. This disk won't wear down as quickly, but being composed of semi-metals, your flywheel will take the beating.
Anyone care to add on?
Old Mar 6, 2005
Boosting Daily
the difference in those 2 flywheels are the weight. The streetlite i believe is 11lbs, and the prolite is somewhere around 8lbs
Old Mar 6, 2005
exturbo6's Avatar
Cool thanks man!!!! Just dont know which clutch to buy still. I was thinking Cerametallic but still not sure.
Old Mar 6, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
How much power do you want to make?
Old Mar 6, 2005
civic01vtec's Avatar
organic has a little slippage which is good for daily driving. The cerametallic engages at a certain point.
Old Mar 6, 2005
exturbo6's Avatar
thank you.now im thining of going with a cerametallic clutch.would rather not slip at all.
Old Mar 6, 2005
what i meant by slippage is that when you are letting out the clutch u can slip it a little bit. With the cerametallic u let up the clutch and then bam, it engages. Kinda hard to explain.
Old Mar 6, 2005
exturbo6's Avatar
which would you choose?
Old Mar 6, 2005
depends on goal whp.....
mine is a daily driver and my goal whp is around 200. I am just gonna go with the organic.
Old Mar 6, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Cerametallic is 3-puck. Think of it as being on or off, no in between. The organic feels more like stock but can hold 69% more torque.
Old Mar 7, 2005
SkyGuy86's Avatar
SkyGuy86 is an unknown quantity at this point
with a new fly wheel and clutch you might be puttin more stress on your tranny as well, but if you're just going to be running 9 to 10 psi the organic should be enough more added torque over stock.
Old Mar 7, 2005
exturbo6's Avatar
thanks...ill be ordering it by tommrow.cerametallic 3-puck and the prolite flywheel.
Old Mar 7, 2005
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
so how much of a "beating" will the flywheel take from the cerametalic clutch?
Old Mar 7, 2005
exturbo6's Avatar
would the prolite not be a good idea then the streetlite?
Old Mar 7, 2005
Alex1's Avatar
i hope u have a strong left leg and no traffic in the part of jersey ur in lol.
oh, and lets not forget about parallel parking in tight spots.
Old Mar 7, 2005
Boosting Daily
the surface of the flywheel will just wear quicker. Same concept follows full metalic brake pads---> warp and wear the rotors much quicker. With a forged aftermarket flywheel, wear wouldn't be something to worry about.
Old Mar 7, 2005
Boosting Daily
Streetlite--> 11lbs
Prolite--> 8lbs
An extremely light flywheel is horrible to drive with boost. IMO, the 11lb is best for drivability.
Old Mar 7, 2005
exturbo6's Avatar
Originally Posted by EternalBlue_Vic
Streetlite--> 11lbs
Prolite--> 8lbs
thanks bro!!!
Old Mar 7, 2005
Your Parts Guy
Streetlite--> 11lbs
Prolite--> 8lbs
Agreed. Streetlite is better for BOOST
Old Mar 7, 2005
exturbo6's Avatar
k, yeah give me a week, chnage in plans..i gotta pay for my 9 day cruise by april, and its 1100 bucks.so im going ot try and buy the clutch and fly wheel asap. hoping by the end of the week.is it possible to rush that ish to nj no later then tuesday?
Old Mar 7, 2005
Your Parts Guy
Depends on when the order is placed but shouldnt be a problem
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
