Engine light on after intake install
Old Feb 21, 2005
Haywood Jablome's Avatar
Haywood Jablome is an unknown quantity at this point
How do I fix this?
Old Feb 21, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
Did you remember to plug the IAT sensor back into the intake? You should have unpluged a sensor when the stock box was removed! U need to plug it back in to the hole on the intake pipe where the rubber grommet is which is near the throttle body!
Old Feb 21, 2005
Yeah, I unplugged it and plugged it back in. The engine light came on about 10 miles of driving after the install. I was told that I need to reset the ECU? Is this true? If so, how do I do this?
Old Feb 21, 2005
In your manual, find the FI ECU fuse under hood and pull it out for a few secs. Or you could unplug the battery but you'll lose your radio settings.
Old Feb 21, 2005
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
^^^ Yeah, try disconnecting ur battery.
Old Feb 21, 2005
Thanks, I did that and it worked.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
SneakerPimp
Bolt-on Engine Performance
Nov 4, 2001 01:12 PM
