ACT clutch goes in dec. 31, ANY TIPS?
Old Dec 26, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
hey guys, welp im finally ready to drop in my new ACT HD00 clutch kit this friday on new years eve, before i do so i was wondering if any of you have any tips or tricks for the install. i imagine someone in here has done this clutch install before, any problems or weird things to watch out for. just by eyeing up the job is looks like its gonna take a good part of the day, especially doing it in my friends garage on jackstands!
Old Dec 26, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
wouldnt suggest doing it on the floor...
i would suggest putting in a new flywheel while ur at it... or at least resurfacing the old one..
tips:
keep all the bolts organized, disconnect the battery, have someone ready to turn the crankshaft to access all the bolts, have threadlock handy
careful to not get any of the friction surfaces dirty with grease and oil... it can cause uneven wear
also.. while ur at it, swap the release bearing...
Old Dec 26, 2004
robo1040's Avatar
yeah im resurfacing the flywheel at work, and i have no choice on where to do it, pep boys where i work wont let me use the shop lifts
Old Dec 26, 2004
robo1040's Avatar
release bearing came with the kit i believe
Old Dec 27, 2004
HyaBoosta's Avatar
yeah it's going to be a pain on the floor. Make sure you have something holding the block up, you can't get away with hoping the motor mounts are going to hold it. and if your on the floor b carefull when the sub frame drops. Good luck. should be a solid 5 hour job if all does right.
Old Dec 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
tips? drive like a grandma until the break-in period is up ;P
Old Dec 27, 2004
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
tips? drive like grandma all the time so your tranny or your axles won't brake
Old Dec 27, 2004
R1Style's Avatar
Hey if you don't mind... could you do up a DIY when finished? I'll be helping Big install his new clutch/flywheel and it'd be nice to have a write up.
Old Dec 27, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
wow man good job with that be careful ive never done a work of that magnitude and i dont think its an easy one make sure you have all tools and power tools will be easier to use and make it faster.
Old Dec 27, 2004
WannaBFast's Avatar
make sure when u do ur bolts on the flywheel use RED threadlock
Old Dec 27, 2004
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
my friend and i installed a new clutch on my car about 2-3 weeks ago. what we did was get a jack and jack up the car. then we put the car on some jack lifts. i think thats what they're called. and then we took the axles off etc etc. for some reason the tranny wouldnt come out. we tried EVERYTHING and we couldnt get the tranny to come out. so we turned the tranny to a certain angle and installed the clutch. just takes a lil longer. but its hard, but if you know what your doing and you get the tranny out, it wont be that hard. i suggest you get some new bushings for the axels too because one of my bushings tore. 10 bucks each at the dealership.
Old Dec 27, 2004
robo1040's Avatar
thanks guys, R1 Style, im gonna take madd pics and do my best on a DIY, were doin it in my freinds garage, hes got like 20,000$ in snap on tools (he is a tech at a dealership) and a compressor so i should be covered there, but the 3 of us who are doin it are kinda goin in blind not having done a 7thgen clutch before.
Old Dec 27, 2004
skipbarber's Avatar
get the honda bible and make sure you torque everything up to spec. Factory service manual gives you a step by step.
Old Dec 27, 2004
mexinaction's Avatar
damn it will be a pain in the ***
good luck to you
and oh yea do a DIY please, plenty of pics that way i might do an install myself
Old Dec 27, 2004
WannaBFast's Avatar
the tricky part is doing it cause you cant take out the tranny.. that part pissed me off...
Old Dec 28, 2004
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
the easiest way is to have the tranny tied to the side in the engine bay. you have very little room to work but its better then taking out the tranny.
btw the manual shows you how to remove the tranny from the bottom i took mines out from the top to swap my busted tranny.i think someone else removed theres from the top too but i cant remember which member.
Old Dec 28, 2004
R1Style's Avatar
Sweeeeeet!
Old Dec 28, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
make sure you have all the tourque specs!
Old Dec 28, 2004
WannaBFast's Avatar
i think its way easier to remove it from the top... altho i dont think that its right..
you probablly wont be able to get enough leverage to tighten the bolts... theres no friggin way you can fit an impact gun in there
an air rachet you can fit in there.. but you cant use that to fully tighten the flywheel bolts
its a 2 person job no matter how you look at it.. dont forget to replace the output shaft seals on the tranny and top off your tranny fluid
the fluid will leak when you pull out the axels..
Old Dec 28, 2004
robo1040's Avatar
from the top, crazy... well i dont have the honda bible nor can i get my hands on one before friday, looks like i should just do it blindfolded, it would be the same thing lol
Old Dec 28, 2004
Civicious's Avatar
Civicious is an unknown quantity at this point
When I swapped my motor, my friends and I found it easier to pull the entire motor and transmission out then to seperate them in the car. You might save more time in the long run when performing the work out side of the engine bay anyway. I have an automatic and pulled the motor from the top. Not sure if this would be more or less difficult for a manual transmission.
Oh, and a Honda Bible is a must!
Old Dec 28, 2004
abmerop18's Avatar
Jam out with your clam out.
cool. thats the same clutch i have. i have had it for about 6 months now and it is awesome. you will love it
Old Dec 28, 2004
robo1040's Avatar
you have the HD00, heavy duty plate and street disk? awesome, im expecting good things
Old Dec 28, 2004
robo1040's Avatar
holy ****, i dont want to have to pull the motor!!!
Old Dec 28, 2004
WannaBFast's Avatar
you dont have to, just makes it way easier to operate on the clutch when its out... lol
Old Dec 28, 2004
robo1040's Avatar
ok ok
SimpleUser
Apr 24, 2021 02:54 AM
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
