Denso IK20 or NGK Spark plugs
where can i get these? can i get these at any local dept. parts store or do i have to order them via internet?
Injen
Injen
you can find the NGKs at most automotive parts stores nowadays. The Densos are still a little more rare at local shops unless you go to a specialized speed shop. The best deal I found on NGK plugs was at www.sparkplugs.com. I haven't been there recently, but I got some NGK Iridiums for my 2jz for $6 each.
NGK iridium IX
$28 for a set
lower voltage requirement
perfect starts with fuel pressure charge
less susceptible to fouling
smoother idle
rated at 60k + miles life
Denso IK20? (is that the right heat range)
Smallest center electrode
short life (some only lasted 10k miles)
smoother idle
price $50+ for a set
All dealers I've asked say ngk works better with honda, even tho some of our cars use denso. If you have turbo, iridium is a bad idea. Use regular copper plugs and change every 1-2k miles.
$28 for a set
smoother idle
smoother idle
i cant say anything for the denso's ,except the stock ones. i get a little better mpg on the iridium. i dont have any engine mods so i dont know, but the ngks work good for me. just make sure you torque them to spec though. i didnt the first time and one came loose and my car starting missing and it sucked.
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
