IF i do my swap
Old Dec 9, 2004
djpolanco's Avatar
djpolanco is an unknown quantity at this point
IF i do my swap
if i take out my d17 and put not sure yet the si 02 or the rsx-r will it just fit or i have to do modifications ? to make it fit ?
Old Dec 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Old Dec 9, 2004
djpolanco's Avatar
can some one help me ???? with this ?
Old Dec 9, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Hey man if you do some searching there is a million threads on here about that. We even have a diy on it right here.. If you just type it in, in the search engine it shouldnt be hard to find a whole lot more.
Old Dec 9, 2004
mexinaction's Avatar
look in the diy section, or go to k20a.org i think is the site they have mad info there
Old Dec 9, 2004
PunkingCivic's Avatar
I need TP for my bunghole
1.Buy some mounts for the engine
--I suggest: Hasport mounts
--Here is a link: http://www.hasport.com/Products/Moun...unt%20ESK1.htm
2. read this:[url]http://www.hasport.com/News/Articles/ESK1others.htm[url]
3. Here are install parts and instructions: http://www.hasport.com/Tech/Installs/ESK1.htm
here is aquick look at the :
Parts Needed
- K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
Old Dec 9, 2004
Here is a quick look at the Parts Needed :
- AC compressor
- alternator
- wiring harness
- ECU
Old Dec 9, 2004
also here is their instal articale with color photos
http://www.hasport.com/News/Articles/ESK1.htm
Old Dec 9, 2004
_Viper_'s Avatar
Wow nice info but man what a pain in tha *** to do it.....
Its not plug and play at all...Would be worth it if you got a totaled car with front end in perfect shape for almost nothing but that is likely gonna happen unless your dad owns a scrapyard
Old Dec 9, 2004
dj02's Avatar
theres plug and play swaps??
Old Dec 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
some B swaps are plug and play
Old Dec 9, 2004
dj02's Avatar
uh yea no derrick no swaps are plug and play.
Old Dec 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
what's your definition of plug and play?
b16/b18 into an ek is plug and play, provided you have a harness, mounts, intake, exhaust, axles. not that hard.
b18 into an em1 is even easier ... same with a k20a2 into an ep3 is plug and play. k20a into a dc5 is plug and play. what the hell are you talking about?
Old Dec 9, 2004
JCiv03's Avatar
edit nt
Old Dec 9, 2004
dj02's Avatar
plug and play. here is the motor put it in plug it in done. thats plug and play
all thoes swaps require you to run new wires, change mounts, change exgaust systems and so forth some are easy some are not. none of thoes are plug and play.
another example changeing ecu, plug and play. get new ecu, plug it in and your done.
Old Dec 9, 2004
_Viper_'s Avatar
well swapping a k20 from a D17 is a tough job..You really have to know what you are doing..Its not like doing a break job.....
What i meant in terms of plug and play is like changing a 305 to a 350 chev..you know you use the same harness drivetrain etc etc..
Please dont flame me i know its not the same thing its just an example...
Old Dec 9, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Originally Posted by aznboysrfr
Old Dec 9, 2004
civicvtec1ps's Avatar
Search and Learn
Search Next Time.
FAQ
http://www.7thgencivic.com/forums/sh...d.php?t=141122
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
