K&N FIPK II
Old Nov 23, 2004
Farage's Avatar
I like you! do you like me?
K&N FIPK II
just installed the fipk II. installation was a breeze. looks great. sound is AWESOME. but didn't feel too much gain. the car def revs easier in the higher rpm's. however, i can see that crazy sound become annoying with time. overall its a great intake. the heat shield was a great idea.
Old Nov 23, 2004
I like it as well. Noticed more throttle response and no low end losses.
Old Nov 23, 2004
shmik1's Avatar
^^ so wuts ur current setup, I thought you posted that you went back to stock w/ a napa filter? so does ur review about intakes letting in too much dirt still stand true? or is that not the problem, or a problem?
Old Nov 23, 2004
It's still a problem, but I've decided to just never clean it. The more dirt, the better it filters the air. I'll let it go at least 50k miles. Someone also mentioned taking apart an engine after a long time with K&N and there was no evidence of damage.
Current setup:
Engine/Performance Modifications:
-NGK Iridium Spark Plugs
-Ground Wire Upgrade
-Apexi VAFC-II
-Optima Yellow Battery
-Ceramic Header
-DH Racing Ported Head Work
-B+M Transmission cooler
-Thermal Rear Section Exhaust
-K+N fipk Air Intake
-AEM Tru Power Pulleys
-Hyper Voltage System
Old Nov 23, 2004
Farage's Avatar
yeah def did not lose any low end power. i was scared of it happening though. hey gearbox, i would like to wrap it in some sort of tape to heatproof the tube more. any suggestions? i was thinging duct tape or electrical tape.
Old Nov 23, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
get some sort of heat wrap, but why duct or electrical? soooo sticky.
Old Nov 23, 2004
Yeah thermotec makes good wraps if you don't mind it looking shiny.
Old Nov 23, 2004
shmik1's Avatar
now I almost wish I had $ for an intake, cause I do like the sound
Old Nov 23, 2004
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
and that would look ugly wrapped in duct tape/electric tape.. I dont think it would even reduce much heat cuz the design of the intake is with plastic or whatever already.. but i dunno!
Old Nov 23, 2004
shmik1's Avatar
could be my imagination but I think my catback gave me better response too.. so im sure the combo of those 2 would be nice..
Old Nov 24, 2004
IronFist's Avatar
You don't need to wrap it. I drove for an hour and then got out and touched the intake tube and it was cool.
Did you reset your ECU? If not the computer will take 200 miles or so to adjust to the new intake (so I'm told).
Old Nov 24, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
I thought the ECU could adjust after about 15 seconds at idle running?
Old Nov 24, 2004
Well it's not known exactly. All I know is when you reset the ecu, the car has to relearn idle by sitting in park with the engine running for 5 mins once warmed up. Now resetting the ecu also clears any stored fuel curves. So it would have to relearn those as well, but that's done when driving. I always thought it was in real time because of all the sensors.
Old Nov 24, 2004
Is there an FAQ about fuel curves.. because I'm wondering, would it have anything to do with me ******* my car out and then for the next couple of weeks I get bad mpg?? Would that be the same thing, or am I thinking of something different?
(sorry to hi-jack the thread)
Old Nov 24, 2004
Not sure. I also don't know whether or not it builds curves based on driving style. Like if you drive slow, it won't build an aggressive fuel curve.
Old Nov 24, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
doyou have a pic of it, is the intake tube plastic or metal? I have seen K&N Intakes for our car and the tube was metal.
Thanks
chris
Old Nov 24, 2004
They have both. The typhoon is metal and the fipk is plastic.
Old Nov 24, 2004
Farage's Avatar
ill post pics in the next few days. anyone know how to reset the ecu?
Old Nov 24, 2004
pull out the FI ECU fuse under hood. Put back after a few secnds, start car, let idle for 5 mins once completely warmed up. It helps if you pull the fuse just after you get done driving, so it's already warmed up and you can start counting 5 mins right after starting the car.
Old Nov 24, 2004
runner1738's Avatar
hey gearbox why do you have the aem pullies along with your optima batttery with your alpine amps doesnt that kind of defeat the purpose of them?
Old Nov 24, 2004
Not really. I have one small alpine amp and the optima. The pullies are underdriving the alternator, so I get more power to the crank. I don't think the pullies will cause any problem with that small of an amp. I only got the battery so I don't have to worry about it getting messed up from deep cycling. I'm not sure what you mean exactly.
Old Nov 24, 2004
gotti's Avatar
Glad the installation was a breeze. Was it worth the $45? (after shipping )
Old Nov 25, 2004
Farage's Avatar
def worth it man. thanks alot.
Old Nov 26, 2004
IronFist's Avatar
Thanks
chris
FIPK II tube is plastic:
Old Nov 26, 2004
Hysteria4u's Avatar
Hysteria4u is an unknown quantity at this point
I'm wondering if the heat shield is sufficient in preventing hot air from getting ingested? Is the filter itself hot after say, an hour's worth of driving?
Old Dec 1, 2004
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
i dont mean to hijack ur thread but any of u guys with the K&N intake notice a loss in the sound it makes when u punch it after a few days of driving. I just put mine in like 2 days ago and when i punched it to lets say like 3.5 on the tach it growled nicely , now it just sounds stock, anyone know what the problem could be? by the way performance is a lil better.
The heatsheild does its job great i drove for over 2 hours the other day, when i got home i popped my hood to see why my intake sounded diffrent i checked the cone to see if it was loose and it was not , nor was it HOT "to answer the last post"
o yah , any help would be super!
Old Dec 1, 2004
Ha yeah. I think when the ecu adjusts, the intake starts to make less noise. It's still there, just not as crazy as the first few days.
Old Dec 1, 2004
fuzzylogic426's Avatar
fuzzylogic426 is an unknown quantity at this point
hey gearbox, were you the one that suggested the purolator filter? if you did, did you switch back to the K&N filter?
Old Dec 1, 2004
Matulin407's Avatar
damn!!!! man, im gonna reset my ecu again, that thing sounded sooooo mean, i got a video of it last night and it sound like a modded GSR.
Old Dec 1, 2004
Don't keep resetting it! You get more power and better gas mileage once it adjusts. And yes, I'm using the K&N filter again. If you never clean it for 50k+ miles, it should get dirty enough to filter decently.
