pulley install
Old Oct 23, 2004
flowerpowerlove's Avatar
just breathe...
flowerpowerlove is an unknown quantity at this point
pulley install
these AEM pulleys are a pain in the butt to install. i sure hope that they are worth it. the local shop was going to charge me 150 to install, but i figured, save some money and learn about the car. plus i think that in addition to the new clutch/flywheel my throttle response will be alot better.
Old Oct 23, 2004
Let us know what happens.
Old Oct 23, 2004
just breathe...
totally. its would be the least that i could do in exchange for the heeps that i have learned from everyone else.
Old Oct 24, 2004
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
honestly...does aem pulleys do anything to our cars???
Old Oct 24, 2004
civiclx4dr's Avatar
civiclx4dr has a little shameless behaviour in the past
exactly cause i wanna install them too
Old Oct 24, 2004
sw388integra's Avatar
you got air tools to help? trying to bust those things loose by arm strength is pretty hard...good luck...
Old Oct 24, 2004
just breathe...
totally!!! the ps pulley is a b***h to get off!!! and the alt pulley is kinda hard to access. im not sure if they add alot, im breakn in my new clutch and am driving slow. i will post after i can start driving again to see if they add to increased throttle response!
Old Oct 24, 2004
orso's Avatar
orso is an unknown quantity at this point
you really need air tools to do that. i found it easiest to just remove the alternator from the car before i changed the pulley. as far as the power steering pulley would should just unbolt it and leave the lines hooked up. i noticed better responsiveness out of the engine. i just seemed to liven up a little bit. the best part is everything on the car works fine ps feels the same and the alternator seems to work fine.
EdGasket
40
Nov 27, 2015 11:11 AM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
