check Engine Light came on...
Old Sep 30, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Hey guys, I put in my DC header and HKS-A downpipe last week and I thought everything was fine...but I failed to realize a picture on my dash was covering the CHECK ENGINE light . My car has been running fine but I don't want anything to go wrong. I know its because i have an o2 sensor unplugged - but will this negatively effect the car?
and if not, is there a way to get the light off? its annoying now that i know its there...
Old Sep 30, 2004
civicvtec1ps's Avatar
Search and Learn
Why is your O2 sensor not connected?
Go get o2 simulator and put it on if CEL bothers you.
Old Sep 30, 2004
where do i get an o2 sim and how does it work? in the HKS-A downpipe there is no spot for the sensor like there is after the cat on the OEM downpipe. thats why its not connected.
My buddy who helped me put on the header/downpipe said he could cut out the bung(i think thats what you call it) in the stock cat and weld it into the HKS-A downpipe where the o2 sensor would plug in...would this help? or would it just show a bad reading and have the CEL on anyways??
Old Sep 30, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Just buy an O2 bung from an exhaust shop for $5. You will probably still get a CEL because the secondary cat monitors catalytic converter operation.
Old Sep 30, 2004
so no way to get around it?
Old Sep 30, 2004
O2 Simulator.
Old Sep 30, 2004
i thought the o2 sim would still bring up a CEL
Old Sep 30, 2004
Depends how good it is.
Old Sep 30, 2004
7gencivicboi's Avatar
7gencivicboi is an unknown quantity at this point
I have an aftermarket hi-flow cat and there wasnt any spot to put the second 02 sensor, so my buddy weld on a nut and then screw in the 02 sensor. or u can get an 02 stimulator and that will do the job also without welding
Old Sep 30, 2004
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
As long as your car isn't in limp mode don't worry about it.
I have a megan hi-flow cat/resonator and when the stock cat was removed the o2 sensor was stuck in the cat. The person who installed it said it would be ok.I still have a CEL but it isn't bothering me.Just don't mess with the first o2 sensor.
Old Sep 30, 2004
jttegx's Avatar
OMNES AD UNUM
^agreed. first o2 sensor (primary: the one before the downpipe and on header) is a must because i THINK it has to do with something reading how much fuel and air the ecu reading?
but a decent o2 sim. may solve your problem depending on your pipes and location.
Old Oct 1, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
If the CEL is on, the car is not running like it should, you should have got the random tech cat... I know it costs more but it has spots for both o2 sensors and it doesnt cause a CEL, I used to have the HKS-A pipe and had nothing but problems so I sold it.... Now i have the random tech cat and couldn't be happier...
Old Oct 1, 2004
not running like it should how? it seems more responsive now with the HKS-A downpipe, but maybe its in my head?? i dunno - I didn't even know the CEL was on because I had a pic of my girl on the gauges, didn't know the light was on til i took a corner hard and the pic fell. lol
how does the random tech feel/sound different from the HKS-A?
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
