O2 simulator worth it?
Old Jun 15, 2004
pinoycivic01's Avatar
pinoycivic01 is an unknown quantity at this point
i'm about to install a kamikazi header and was wondering will the check engine light go on? if so will i have to get a O2 simulator...is it worth it? if the check engine light is on will it lessen the performance of the car? this is on a 2001 civic lx
Old Jun 15, 2004
civicvtec1ps's Avatar
Search and Learn
"The motor will lean out the fuel mixture making the car seem faster, at first. Then after three drive cycles if the condition has not been fixed- which it wont with no cat- the car will trigger a MIL.
When the MIL is triggered, the car will then change to a rich running condition in safety mode. The computer will also retard the timing and will do several other things to reduce the performance of the car in order to reduce smog output and make sure the motor does not blow up.
It may also effect the warranty of the vehicle if driven in safety mode over a long period of time.
The car will eventually run slower if the check engine light is not addressed.
The car may be faster at first, but in time it will not run correctly.
This is a FACT."
After all, Just get O2 sim and be happy.
Old Jun 16, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
if you have to remove the o2 sensor then make sure there is a place for it on the the header other wise just the header shouldn make it go on. I have an ex and with just the header i didnt get the engine light.
Old Jul 1, 2004
lid6662's Avatar
lid6662 is an unknown quantity at this point
I just installed my highflow cat and I MIL came on after about 30 miles!
I have a A\f gauge and so far it seems to be running fine and I cant notice a difference if it did go into limp mode? When chillin at a light what does your a\f read? Mine normaly is in orange and moves around a little bit!
Any more updates?
Old Jul 1, 2004
Search and Learn
Ok Heres Some updates i found on Clubrsx.
I have been researching ,because i am going to put race header shortly and it will throw CEL.
Seems like, Most of o2 sim work fine exception of few.
There were many times CEL come on and off occasionly even with O2 sim.
I have decided to just run race header without o2 sim.
I will just drive around with CEL light on until i can afford to upgrade to hondata kpro(options for kseries motors..)
One member from clubrsx had o2 sim and ended up with fried ecu couple months later.
Old Jul 2, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
in limp mode that you get if the first o2 sensor is bad or reading incorrectly it will not let you rev higher than 3000
Old Jul 2, 2004
lid6662's Avatar
Well I reset the ecu and the a/f gauge read like normal! Rich at 80% throttle. WHen idling when bouce from from lean to rich and not stay there for long at all. ANd some time when I let off the gas there would be no reading....
So Seems to be so far the the check engine light has not messed up my af gague reading? I installed the a\f gauge to the o2 sensor by my ex header.
Would it be better if i ran it to the ecu?
Old Jul 2, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
damn im sooooo afraid of the ex convertion
i have everything i need to the convertion....(ex aftermarkte header, ex downpipe, ex extended O2 sensor wire)....and still im scare to put it on.
god damn!!! i hate this feeling....i know it will be ok....but something in my heart saying "dont do it, dont do it, ur engine light will go on"
so plz pl zplz pz plz some help me out with a straight answer....someone that has done the legal way....plzp lzplzplz give me a straight answer
Old Jul 2, 2004
HOOCHYboi's Avatar
HOOCHYboi is an unknown quantity at this point
my engine light has been on for over a year and i don't see a reduce in power...
Old Jul 2, 2004
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
i bought the casper O2 simulator but haven't installed it yet... should be taking care of it tomorrow...
Old Jul 8, 2004
518's Avatar
518
518 is on a distinguished road
Where did you buy the ex extended O2 sensor wire? Or is this the one for EX application and we, DX/LX owners, call it extended?
I'm waiting for the EX Header to arrive. Everything else is here.
Did you get the EX front swaybar also? If not, then you need it.
Does your EX downpipe has a cat? I bought the RandomTech hi-flow along with magnaflow, if you must ask.
Old Jul 9, 2004
Diablo's Avatar
you might wanna think about running it with the light on i have had mine on for a wile and my car is starting to run like sh-t plus the exhaust really smells(high flo cat). i orderd a mil eliminator from bigjoshracing ill let you know if it turns the light of. its cheaper than a o2 sim and does the same sh-t $21 shiped.
Old Jul 9, 2004
Search and Learn
Well, I have Hondata Reflash and they do not recommand running o2 sim.
Cel comes on once in awhile but i just reset ecu.
No big deal, Car performs fine.
It's going to smell anyways.( Cat is gone )
Old Jul 9, 2004
518's Avatar
518
Can someone please tell me what and where to get the so called EX extended O2 sensor wire mentioned by our member Civic_Racer9?
Is this just the O2 sensor wire for the EX model? And, we LX owners, call it 'extended' since it extends to the bottom of the EX cat?
Thank you.
Old Jul 9, 2004
Search and Learn
Thank you.
http://www.casperselectronics.com/Me...ory_Code=honda
Old Jul 9, 2004
518's Avatar
518
you my friend, rocks! I can just send you $10 for giving me that link
Old Jul 9, 2004
lid6662's Avatar
Dam 79 for that does it work for sure?!
Old Jul 9, 2004
518's Avatar
518
I wasnt looking at the o2 sim. I was looking at the extended o2 wires which is $27 including the new end-connector.
But someone talked me into buying a wire to use as an extension.
Old Jul 9, 2004
Search and Learn
No Problem.
Old Jul 16, 2004
lid6662's Avatar
Well something weird but cool happened tonite
I leaving work and got in my car and put the key in it. Then I started my car and to my amazment there was no check engine light? I have a
tsudo cat back, cai ,obx header, I had no problem with check eninge light Butwhen I got my highflow cat It poped on in under 35miles . Reset the ecu for the second time and it came on under 20 lol. So I put about maybe 1500 miles on my car with the light on..... But I got off work and no check engine light I just got a oil change about 500 miles before but other than that the only other thing I did to my car was put the whole back interior back in lol! When I drove to work I am somewhat sure if it was on. But knowing me I should have noticed it lol
I hope the light does not come back on....
Old Jul 18, 2004
lid6662's Avatar
Ok update the light came back on but this time after 80+ miles of driving.
My friend has a obd2 reader and said that he erased the code or something.
The hookup for it was right under by the steeering wheel.
Old Jul 18, 2004
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
The OBX and Kamikaze headers for the LX Civics are not worth it. They dont have a place for the cat. You cant move the cat either cuz the ecu will record the errors and for those of you who do get their inspections you will have a hard time passing with all of those error codes on your ecu. O2 sensor or no O2 sensor, it aint worth it. Besides they are only worth about 7 hp. Dont waste your money and effort on it.
Old Jul 19, 2004
Hey guyz I have an update on the situation with the OBX and Kamikaze headers. I talked to both companies and they said there is no way to customize the setup to be smog and carb legal. All that stuff about Ex conversions is obsolete. You cannot move your cat. to another location cuz the computer is programed to operate with the cat where it is. If you move it your computer will not operate correctly and your car's performance will decline. If you dont care about passing inspections or getting tickets for smog violations than do what you want to do but be advised that you are going to run into alot of problems down the road. Even if it doesnt seem to be causing problems immediately after installing, it will eventually. Not to mention that these headers wont give you much if any hp boost at all. About the only thing they will do is make your exhaust sound a tad louder and more grumbly but to me that isnt worth the trouble of getting it to operate properly.
Dawit Melese
Oct 4, 2015 08:02 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
Jrosa
Sep 14, 2015 08:24 PM
Bikergofast
Sep 12, 2015 01:36 PM
