DH Ported Head INSTALLED!
Old May 31, 2004
  #61
Here is how I did the ports.
http://2k1civic.com/forums/showthread.php?t=154478
They drained the coolant by taking off the white plug on the radiator to let most of it out. Then they squeezed that big hose between battery and header until most of it came out. There will still be some left around the head when you pull it out. Oh and oil spilled all over the front of the car when they removed the head. I guess it was all over the little spaces inside.
Old May 31, 2004
  #62
jrock2324's Avatar
jrock2324 is an unknown quantity at this point
How did they get it out around the head? I am asking because I am trying to get it out around my head. When I take my head off oil spilled all around the head.
Old May 31, 2004
  #63
ImportRacer2123's Avatar
K20 Member
here try this
http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
Old May 31, 2004
  #64
More problems!
It just rained tonight and now when I'm accelerating into a turn, I hear this nasty clicking/creaking noise. What could it be? Sounds really bad.
Also, the car is vibrating back and forth when at idle. If I'm in D and let off the brake, the car will shake. Almost feels like warped rotors or something.
Old May 31, 2004
  #65
Now I'm also noticing some kind of water noise. I think from air in the coolant or something. Anyone know what to do about it?
Old Jun 1, 2004
  #66
Havok2k1's Avatar
Wicked Pissah Admin
You may want to go over the whole install. Sounds like some stuff got loosened up there... Vacuum leaks or loose bolts... Vacuum leaks can cause a rough idle or a motor not starting. The rattling might be a misfire. Maybe a sensor plug loose? Just go through the whole thing and make sure all connection are tight...
And put the three intake bolts in....
Good luck man, nothing like some old fashioned NA power!!
Old Jun 1, 2004
  #67
K20 Member
it could also be your header rattling against your front core support...
Old Jun 1, 2004
  #68
Well I'll look again, but that water noise just started after the rain. Very strange. And I'm afraid that rough idle might be from the higher compression throwing off cam timing a little. Looks like I may be getting a new cam gear. Is there a way to get bubbles out of coolant system?
Old Jun 1, 2004
  #69
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
you might have to remove the black plastic cover that goes on the head but im not sure if it will clear even after that
Old Jun 1, 2004
  #70
djmota's Avatar
To bleed the air out of the cooling ststem take off your radiator cap(when cool) then run your engine until the cooling fans come on. Let it idle a few minutes after that and it should be bled. I have pm'd you on the cam gear situation. :0 For the rattling grab your downpipe (when cool) and give it a shake It should move freely with the tension of the spring bolts keeping it sealed. If it does not move make sure that the spring bolts are installe properly and the shoulder of the bolt is not hanging up on the flange of the downpipe. enjoy
Old Jun 1, 2004
  #71
Thanks. I somehow got two of the intake mani bolts on from the sides leaning over the car. I'm gonna try the coolant bleeding thing and play with the fuel curve.
Old Jun 2, 2004
  #72
Well I set my vafc wide settings like wannabfast had done and it seems faster. I still don't know if it's right or not, so eventually I'll have to get i tuned.
Old Jun 2, 2004
  #73
K20 Member
What were his settings?
Old Jun 2, 2004
  #74
Any Updates?
Old Jun 2, 2004
  #75
All I know is last night after changing the fuel curve, the car felt alot better. I left the vtec engagement stock.
Next thing I need to do is put the stock muffler back on, because that Thermal rear section I have is causing the rpms to bog around 30mph. I need to call home and have them ship it to me.
So I still have that bad rattle and noise, but I don't know where it's coming from. I think that fuel system treatment is also helping. Now right after a shift, you can feel the car pulling even better.
Here are the settings. He only tuned them for wide throttle, and his setup is alot different. He has custom exhaust, intake, downpipe, and header I think. So I don't know. It seems to be helping me out. A few points are negative, and I'm not sure if that's cool or not for me.
Originally Posted by WannaBFast
well.. rather than wait for someone to post their settings, i went and got it slightly tuned.. well i only tuned the wide throttle settings... well i got like an extra 10hp with these settings, yea yea.. it probablly will be different for you guys, but lets just say the closer you are.. the less time and money it will take to make urs perfect...
Settings -> Wide Thr
Wide Low Vtec
1000 +0
1400 +2
1800 +4
2200 +4
2600 +5
3000 +5
3400 +2
3800 -2
4200 +1
4600 +0
Wide High Vtec
3200 +0
3400 +0
4000 -4
4400 -2
4800 +0
5300 +3
5600 +3
6000 +3
6400 -1
for the vtec engangement this is what i had
L -> H 4000
H -> L 3800
hopes this helps you guys save a buck or two...
Old Jun 2, 2004
  #76
djmota's Avatar
his settings are a good starting point I used them too before I dyno'd.
However you will not need to use any of his neg. numbers. leave them zero at the least. Vtec engagement is best laft stock. its fun to play with but stock is by far the best for power. If you want to feel a 15-20hp kick, set the vtec to 5k rpms. we did it once on the dyno just for fun.
Old Jun 3, 2004
  #77
Haha. Okay, I'll set the negatives back to zero. I do feel a difference as it is now, but only when I get on the gas. I think I'm starting to figure out how it works. So the wide settings only engage when throttle is at 50% or higher then? Then for the narrow it's at 10% throttle? But I don't have the narrow ones set yet. Should I just set them the same as the wide?
Old Jun 3, 2004
  #78
IronFist's Avatar
What if you're between 10-40% throttle?
Thanks for the explination of wide and narrow, tho. I was curious what that meant.
How much could you get from a VAFC II with just bolt ons?
Are there any dangers of having it set wrong?
What do the + and - mean? Does that have to do with how much fuel it is getting?
Thanks.
Old Jun 3, 2004
  #79
Well I'm assuming the narrow settings take effect between 10-50%, and the wide settings take effect after 50%. I think that's why I feel a difference when the gas is pressed down more than half way. I only have the wide settings and not narrow, so driving it slow almost feels like stock.
I think wide throttle is like wide open throttle (pedal floored). Narrow is just normal driving. And actually the vafcII lets you adjust the 10% and 50% values.
The + means more fuel, the - means less fuel that stock (baseline). You actually can see the graph as you adjust the settings. Wannabfast said the settings above for wide gave him 10hp with boltons. I could feel a difference for sure with my intake, header (both same as yours), and ported head.
Old Jun 5, 2004
  #80
IronFist's Avatar
Rock on then.
I'd consider getting a VAFC II if I had more info about it. Is it easy to install? I don't know anything about electronics.
Old Jun 5, 2004
  #81
It was easy enough, just wire tapping. I did a bad job because of the limited space and probably should have soldered the connections.
Trying now to get the cam gear on, but I don't know what advance/retard means and how to set it.
Old Jun 5, 2004
  #82
IronFist's Avatar
How's the long term wear on our cars with VAFC II? Gas mileage? Etc. etc., the same old questions.
Old Jun 6, 2004
  #83
I'll have to get back to you on that. Right now I just have a little fuel being added. I doubt it will hurt anything, since it's just balancing out the extra air that's coming in.
UPDATE: I messed up bigtime trying to install the AEM cam gear and have given up. On the plus side, car is running great. I used some TB cleaner and I think my idle is back to normal now! I'm near the end of another tank again, so I'll go flooring it a bit more and then start driving normal again.
I think I'm gonna go back to stock muffler, because it's probably what's causing the rpm bog around 30mph.
Old Jun 6, 2004
  #84
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
Good to hear that things are working better for you. What happened this time with the CAM Gear? I am still waiting on the Intake manifold, then I will be putting my P&P head on with a 74mm TB. Gonna need larger injectors though!
Old Jun 6, 2004
  #85
Yeah, I'm keeping an eye out for that. I know someone that can get me a deal on RSX injectors, but I need to know if they'll fit.
Don't ask about the cam gear. I just want to sell it and never see the thing again. But everything is fine now I hope.
Are you installing the pnp yourself? Don't forget new gaskets, head bolts (10), and oil/coolant. And you should port match the exhaust mani and gasket to the ports on the head for best gains.
Old Jun 6, 2004
  #86
I only asked about the cam gear because I still plan on installing it on my car, without the dust covers.
I think am going to get some RC 550's for my car, but I will need to modify the fuel rail a bit for them to fit.
Old Jun 7, 2004
  #87
Any suggestions on the rough idle? Someone said I should get a kit to dial in the cam setting or something. Don't know much about it.
http://store.summitracing.com/partde...art=CCA%2D4796
Cam gear is just a pain and I couldn't put it on without messing up the timing. I barely got the stock one on with the belt. Spent 2 hrs trying to get it back on. And then I've heard that since the AEM has only 3 adjusting bolts, there's a chance they might break or move so that the cam setting is changed.
Old Jun 7, 2004
  #88
That's neat. I think it means you can adjust your stock cam gear. What a deal. That might work for you, anyone else comment on this device.
AEM ca gears have to be re-adjusted once in a while because the timing might slip a bit over time, unless they hit the dust cover.
159
Jul 5, 2015 09:54 PM
HondaHomer
May 14, 2015 12:24 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
